Введение
Use this guide to replace a broken display.
Выберете то, что вам нужно
Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
Pry the top bezel off the adhesive securing it to the display retainer.
Remove the two angled Phillips screws from the two corners of the display retainer.
Insert an iPod opening tool between the outer case and the display retainer.
Use the tool to slide the display assembly out of the case slightly.
Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
While holding the light colored socket down with one finger, use the tip of a spudger to flip the ZIF cable lock up toward the bottom of the Nano.
Use an iPod opening tool to peel the display data cable off the thin metal plate attached to the display.
Pull the display out of the Nano, minding the hold switch cable that may get caught.
5 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
I followed all the directions carefully, using the correct tools, and viola...I now have a working iPod. Thanks iFixIt! :)
