iRobot Braava 320 Wheel Replacement
Выберете то, что вам нужно
  1. iRobot Braava 320 Wheel Replacement, Battery: шаг 1, изображение 1 из 1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
    Спросите у FixBot
    Добавить комментарий
  2. iRobot Braava 320 Wheel Replacement: шаг 2, изображение 1 из 1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
    Спросите у FixBot
  3. iRobot Braava 320 Wheel Replacement: шаг 3, изображение 1 из 2 iRobot Braava 320 Wheel Replacement: шаг 3, изображение 2 из 2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
    Спросите у FixBot
  4. iRobot Braava 320 Wheel Replacement, Body Shell and Control Panel: шаг 4, изображение 1 из 1
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
    Спросите у FixBot
  5. iRobot Braava 320 Wheel Replacement: шаг 5, изображение 1 из 2 iRobot Braava 320 Wheel Replacement: шаг 5, изображение 2 из 2
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
    Спросите у FixBot
  6. iRobot Braava 320 Wheel Replacement, Wheel: шаг 6, изображение 1 из 3 iRobot Braava 320 Wheel Replacement, Wheel: шаг 6, изображение 2 из 3 iRobot Braava 320 Wheel Replacement, Wheel: шаг 6, изображение 3 из 3
    • To remove the wheel covers, hold the wheel in place with one hand while turning the cover clock-wise with the other.
    • The cover should come off as soon as you hear a 'click' sound.
    • When replacing the cover, align the notches on the cover just to the right of the ones on the wheel.
    Спросите у FixBot
  7. iRobot Braava 320 Wheel Replacement: шаг 7, изображение 1 из 3 iRobot Braava 320 Wheel Replacement: шаг 7, изображение 2 из 3 iRobot Braava 320 Wheel Replacement: шаг 7, изображение 3 из 3
    • Using a small Flathead screwdriver, remove the small black clip in the center of the wheel.
    • To ensure the clip does not fly off, place your hand over the wheel to cover it as you remove the clip.
    Спросите у FixBot
  8. iRobot Braava 320 Wheel Replacement: шаг 8, изображение 1 из 3 iRobot Braava 320 Wheel Replacement: шаг 8, изображение 2 из 3 iRobot Braava 320 Wheel Replacement: шаг 8, изображение 3 из 3
    • Once the small black clip is removed, the wheel should come off by gently pulling on it.
    • Be careful not to lose the two small chrome pieces located on each side of the wheel.
    Спросите у FixBot
Заключение
14 человек успешно провели ремонт по этому руководству.
Ruven Tapia-Vargas
Участник с: 02/28/17
409 Репутация
1 руководство автора
Команда
USF Tampa, Team S1-G3, Nance Spring 2017 Участник USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 членов
Автор 10 руководств
1 Комментарий к руководству
O roteiro descritivo para a troca das rodas do Braava foi muito útil. Obrigada!
Vanilda Chueiri - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 48
За всё время: 10,679
