« Обратно ко всем историям
SSD and RAM Upgrade
slc0705 -
Mac mini Mid 2011
Картинка к истории
Installing Mac mini Mid 2011 Dual Hard Drive Kit
2 - 4 часов
Moderate
Моя проблема
I record a lot of screencasts, and needed a quiet device from which I could record virtual machines along with my voiceover. My Mac Mini would do the trick, but needed more RAM and a speedy and quiet drive. This SSD fix looked like a good solution.
Мое решение
The repair was straight forward. I ended up keeping the original HDD for secondary storage and I still cannot hear anything while the machine is running. I am running Bootcamp can can dual-boot OS x/ Windows as well as run any virtual machine environment I choose. Very happy with the results.
Мой совет
Take your time, there are a lot of steps. I laid down a bunch of paper on my desk and put the parts on them with the step number next to each part. This made the reassembly process easier. Test everything before spending a lot of time configuring software. You are working with connectors to power, IR, Bluetooth, multiple drives, and Wifi. Make sure it all works as soon as possible while the process is still fresh. I ended up knocking my second SATA connection loose while sliding the cowling back in. The attached photo shows Windows 8 running virtually from the windows 7 bootcamp partition.
Mac mini Dual Drive Kit Изображение
$29.99
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 10
За все время: 95
