« Обратно ко всем историям
MacBook SSD Upgrade
Eric Outen -
MacBook Core Duo
Картинка к истории
MacBook Core Duo Hard Drive Replacement
10 минут
Easy
Моя проблема
This wasn't necessarily a fix, but I wanted to speed up my 2007 MacBook because it still works great for Photoshop and Illustrator. I was also holding off upgrading the OS to Lion until I could get an SSD so the installation process would be less tedious. I purchased a Crucial 240GB SSD from Amazon which is double the storage of the 120GB SATA that came with the MacBook.
Мое решение
The hard drive swap couldn't have been any easier. I might have hit a snag if I didn't already have a screw driver set with Torx screw bits, but the screws stick out far enough that someone could unscrew them with a small pair of pliers I suppose. I don't think it took longer than ten minutes to swap the hard drives and get everything back together.
Мой совет
I would highly recommend reading through the guide carefully and making sure you have a set of Torx screwdrivers available. Otherwise, if you're comfortable with removing the battery and undoing a couple screws I don't think you should run into any problems.
TR8 Torx Security Screwdriver Изображение
$5.99
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За все время: 775
