« Обратно ко всем историям
Replaced iPad Air Front Panel
maliawaddell -
iPad Air Wi-Fi
Картинка к истории
  • Изображение #1
  • Изображение #2
  • Изображение #3
iPad Air Wi-Fi Front Panel Assembly Replacement
2 часов
Difficult
Моя проблема
My iPad had the ghost touching problem, where it just started freaking out and opening apps without being touched. My research pointed to a digitizer problem. I also had a small cracked screen area.
Мое решение
I had mixed results. Eventually I fixed it. Getting the original screen off with all that adhesive was no joke. I also cracked my replacement screen trying to install the home button and had to order another. The home button still doesn't respond as well as the original. But I have a functioning iPad again! So I'll consider it a win.
Мой совет
Definitely order the replacement assy that has the adhesive and home button pre-installed. A razor blade and a blow dryer were my main tools used to remove the screen.
iPad Air Screen Digitizer Изображение
$29.99
1 Комментарий
Sounds tricky, but glad you worked it out!
Cynthia Replogle - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За все время: 166
