« Обратно ко всем историям
Back in Business!
Ronald Mitchum -
iPhone 5c
Картинка к истории
iPhone 5c Battery Replacement
10 минут
Moderate
Моя проблема
The battery that I bought from New Egg was crap
Моё решение
Went great, Great kit, everything included. Did it before with another kit which was not as good.
Мой совет
If you do not take off the screen, just make sure it is supported at a bit less than 90 degrees, so you can use both hands. Small screws on the battery hold down, the magnetic drivers in the kit work very well. In the previous replacement I had trouble getting the OEM battery out, the tabs broke off, so just take a heat gun or hair dryer on low and carefully heat the underneath of the case a bit, if it feels hot it is too hot, heat only the battery side, the battery will start to give way using one of the kit tools, take a lot of time to do this maybe 10 minutes off and on. I work under a magnifying light.
iPhone 5c Battery Изображение
iPhone 5c Battery
$29.99
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 108
