« Обратно ко всем историям
2011 iPhone 4s First-Time Battery Replacement
Leandro de la Rosa -
iPhone 4S
Картинка к истории
iPhone 4S Battery Replacement
3 часов
Moderate
Моя проблема
The battery's lifespan has severely degraded after 7 years. The indicator gets stuck on 1% for a long time.
Мое решение
It went well with the exception of the removal of the 1.7 mm Phillips screw by the battery connector. The reason it took my battery replacement process 3 hours is that I stripped the aforementioned screw. The included iFixit screwdriver's Phillips screw attachment for reason didn't go well with the 1.7 mm screw. After I miraculously removed the stripped screw, everything else went without a hitch.
Мой совет
Don't strip any screws. If you think you are careful during the unscrewing process, you should probably be a little bit more careful.
iPhone 4S Battery Изображение
iPhone 4S Battery
$18.99
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За все время: 238
