« Обратно ко всем историям
Digitizer disaster
Ken Spires -
iPad Air Wi-Fi
Картинка к истории
iPad Air Wi-Fi Front Panel Assembly Replacement
2 часов
Moderate
Моя проблема
It was cheaper to fix than replace, plus I LOVE a challenge.
Мое решение
I was a little nervous. I have replaced several iPhone screens, but this was my first iPad. Clear a spot at a bench, spread out a darker colored (lint-free) fabric. I use dark so that tiny screws, etc. will stand out. Also, if you have access to an anti-static mat, that is better.
Мой совет
If you are not using an anti-static mat, be sure anytime you let go of whatever you are working on, you ground yourself to the metal frame before proceeding. Do not rush, follow instructions, BE GENTLE! I used clear packing tape to keep the digitizer together while working with it. It also kept small shards from sticking out and cutting me. Use clear tape so you can still see the LED display. Be diligent when cleaning old glass and seal fragments. Be patient.
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 19
За все время: 122
