Введение
Welcome to day three of our week of game console teardowns. So far we've taken apart the Magnavox Odyssey 100 and the RCA Studio II; the Atari 2600 is next! We partnered with PC World for this teardown to bring you a peek into another staple of game console history.
Originally labeled as the Video Computer System (VCS), the Atari 2600 was released in 1977. By that time, microprocessor-based hardware had been popularized with the Fairchild Channel F, and the VCS was Atari's first foray into that technology.
The system was originally released with all six switches on the front of the console, however, the console was redesigned in 1980 with only four of the switches on the front, and the other two on the back. The console featured here is a post-1980 model.
Выберете то, что вам нужно
Atari 2600, with AC adapter and iconic joystick controller.
Does the 2600 have a hardwood finish? You are correct sir!
Video game consoles these days may not have a sense of home decor, but some computer companies still believe in the aesthetics of wood paneling.
At its release, the 2600 sold for $199. In today's coin, that's $696. In comparison, the launch model of PlayStation 3 cost only $599. Prices are coming down!
As soon as users figured out that the Atari 2600 could play more games than just Pong, the 2600 became massively successful. It went from selling 250,000 consoles in 1977 to 1 million units in 1979.
From its release in 1977 until 1983, the Atari 2600 was officially called the Video Computer System, in response to Fairchild Semiconductor's Video Entertainment System. The console was later renamed after its model number, CX2600.
Instead of following the trend of building a limited number of games into the system like the Magnavox Odyssey 100, the Atari 2600 used removable cartridges to store games like Space invaders, Pac-Man and Pitfall!
Each player could select the difficulty of the game they were playing by simply flipping a switch from "A" to "B". Which one was harder is anyone's guess.
In regards to the difficulty switches, switching to "B" was the easier setting and switching to "A" was the harder setting. Some examples:
Missile Command:
A: Make the missiles you launch slower
B: Make the missiles you launch faster
Space Invaders:
A: Makes your base bigger (and most likely to be hit)
B: Makes your base smaller
Asteroids:
A: UFOs appear
B: UFOs does not appear
Hopefully the information I provided here will help those confused with the difficulty switches.
The "anyone's guess" comment was inappropriate. The system owner's manual mentions in section 5 that position "A" is generally more difficult than position "B". Every game instruction manual described exactly what the functions of the difficulty switches were for that game, if they did anything at all. There are a few games which were inadvertently made with difficulty settings reversed from the standard.
Dude. No one cares.
I totally care!
I care deeply. But where is the switch? Is it underneath the console?
On the console shown in this article, difficulty switches are on the back upper edge (visible above the cartridge port in the photo above at Step 2 of this guide). This puts each player’s difficulty switch just inboard of his or her controller port.
On consoles with 6 silver-colored front panel switches, the switch nearest the cartridge port on each side is the difficulty switch.
There are four screws holding the upper and lower case together.
Hmm, these screws in the back are at an odd angle: almost 30 degrees off of vertical! Strange.
With such a large console, there must be a ton of awesome components inside...
...Or not. Seriously? That's it? The case design team must have wanted to give lots of breathing room to the motherboard team, just in case. (Actually this is the third version of the internal hardware, the first took up much more of the case.)
Jay Miner was able to integrate the display and sound chip into a single IC, thereby reducing the footprint of the motherboard, but the case size still seems rather hyperbolic.
With a design that is unseen in just about any other electronic device, the motherboard is propped up and sits at an angle of 30 degrees inside the Atari. Now those case screws make sense!
The case design seems unusual even when you consider the original, 6-switch model. See here: http://www.longhornengineer.com/Videomod...
The reason for the case being so large was that originally it included two speakers for stereo audio output. These were deleted at the last minute in favor of mono audio through the TV as a cost-saving measure, but the very earliest 6-switch consoles have circular-layout speaker slots in the top and support posts cast into the case bottom. In fact, it took Atari quite a long time to completely close off the speaker slots, as even some of the 4-switch models (like the one used here) still have them. I've even seen case tops with speaker slots on only one side!
Here's a much better picture of the insides of a 6-switcher: http://oldcomputers.net/atari-vcs.html
I guess that the round tripods near the front of the case were for holding the speakers.
cityzen -
This photo should be replaced, as it shows incorrect routing of the RF cable (apparently someone has opened this console before). From the RCA socket on the motherboard, the cable should be placed thus: first, it should go toward the *front* of the console (from a player's perspective; i.e. "southwest" as the console is positioned in the present photo) alongside the main EMI shield, and between that shield and the RF modulator unit. Then it should turn 90 degrees toward the player's right and be pressed into the slot in the top of the fat round post. Then it should make another gentle 90 degree turn to head toward the rear of the console and be pressed in place between the small hollow post and the fin beside it, which supports the case top. Proceeding rearward, the cable may either be pressed between the pair of fins, or between the rightmost fin and the case side (as the pair of fins are actually a bit too close to one another) before winding around the remaining plastic bits to finally make its exit from the rear of the case.
Finally, cables that are not soldered to the board! (Take note, Studio II.) The RCA cable is easily removed.
The motherboard easily lifts out, as there are no additional screws or clips holding it in place. The only thing securing it down were the angled screws we removed from the outer case.
The motherboard measures 9.75" x 5.25" and the lower case measures 13.75" x 9.75".
The case of the 2600 is 2.6 times larger than the motherboard!
The motherboard of the 2600 is dominated by an ominous metal box, likely the EMI shield covering the ICs.
Our efforts to access the brain of the Atari are temporarily thwarted by four metal tabs.
A few short twists with pliers and the EMI shield lifts free.
Atari gets a +1 on repairability for not soldering the shield to the motherboard, as some recent manufacturers have done.
Brains!
The Atari 2600 boasts:
1.19MHz 8-bit processor
128 bytes RAM
192 x 160 pixel resolution
128 colors, with max 4 colors per line
2 channel mono sound
Unlike most earlier consoles -- where the games were stored on internal chips -- the Atari 2600 stored games in Read Only Memory (ROM) chips housed in external cartridges. This allowed for a potentially infinite number of playable games for the console.
The three main chips are socketed (!) for easy replacement.
Yes, socketing the chips DID make replacement easy. However, because they are of the DIP (Dual Inline Package) design, they have one annoying flaw: They tend to "walk" out of the sockets over time. Here's how it happens: When you turn the system on and off, the internal circuitry heats up and cools down. This causes expansion when heated, and contraction when cooled. Over a period of time, this causes the chips to "walk" out of the sockets, causing bad contact and the system will fail to power up. The solution is to open it up and reseat the chips back into the socket. This is one annoying thing about that design. The original IBM PC had a lot of sockets for its memory, and when the event I described happens, the computer would refuse to power up. That's the reason why SIMMs and DIMMs were introduced.
It's interesting to note that the 6507 was a 6502 with some data lines deleted. This meant that the 2600 can only access up to 4K. However, some companies used a bank switching technique, so some cartridges had as much as 16K! That was quite a bit in those days, as memory was pretty expensive.
The top two chips are the 6532 Ram-I/O-Timer (RIOT) chip and MOS Technology's 6507 CPU (a slimmer version of the more popular 6502). By the current revision, they were manufactured by Synertek and Rockwell, respectively.
Atari's custom chip, the Television Interface Adapter (TIA) is the moneymaker of the 2600, as it allowed for multiple colors, increased graphic capabilities, and sound.
Because memory was so expensive during the 2600's design, the video processor has no external RAM. As a result the CPU must send video data to the TIA one line of video at a time.
There are six components of video that the TIA can create: The playing field, Two sprites (8 pixel lines), a "ball" (single pixel), and two "missiles" (two pixel lines). Combinations of these elements allowed for the complex video games witnessed in the 2600.
Pretty sure that the 6507 in that picture has a MOS Tech mark on it, not Motorola. The chip on the bottom (which I think is the TIA, not 100% sure) appears to have a Motorola mark on it, though.
Indeed, Motorola did not make the 6502/6507, although they could have. The history is interesting: http://en.wikipedia.org/wiki/6502
cityzen -
Oh, and the 6507 has a Rockwell logo on it. Rockwell licensed the 6502/6507 and eventually came out with their own versions. Synertek was another licensee.
cityzen -
With the EMI shield removed, all the components of the motherboard are visible.
Color tint adjustment
Sound tuner
RF modulator
Cyan Engineering TIA custom chip (manufactured by Motorola)
MOS Technology 6532 RIOT (manufactured by Synertek)
MOS Technology 6507 CPU (manufactured by Rockwell)
Voltage regulator (manufactured by Texas Instruments)
The back of the Atari 2600 Motherboard has exactly nothing interesting on it, except a great appreciation for through-hole soldering and hand drawn circuits.
This model was revision 13. How lucky!
I think that the giant solder blob underneath the voltage regulator is kind of interesting. I'll have to keep that technique in mind when I need a DIY heatsink in my own projects.
Also kind of interesting are the wrinkly traces. This is due to "hot air solder levelling" (HASL) where the traces were coated with solder before the solder mask was applied, which helped reduce corrosion and with wetting at nearby joints. During the later wave soldering process, the HASL solder would melt again under the mask, and wrinkle as it cooled down. You can see this on a lot of 1970s and 1980s PCBs.
Behold the Atari in all five of its parts!
We give the Atari 2600 a big plus for repairability. Every component is attached via through-hole solder, so replacing a burnt out resistor or IC is quite feasible.
We're sad to say that we don't have parts for the Atari 2600, but we do have a brand new game console parts store to help keep your (slightly more modern) consoles running.
Keep an eye on our teardown page or blog for a detailed look at another retro game console tomorrow!
18 Комментариев
Your IC ID on this teardown is incorrect.
The Rockwell chip in the middle CO10745 is the 6507 CPU
The Motorola CO10444 is the TIA and the Synertek is the 6532 RIOT IC
-John
Curator
The CPU Shack Museum
www.cpushack.com
Agreed, and I don't get how you guys came to the conclusion of "a great appreciation for [...] hand drawn circuits".
I see nothing but straight lines, which very well could be neatly hand drawn, but just as easily could be CAD'ed.
But otherwise I love your teardowns of classic hardware. Keep them coming!
Michael -
Perhaps they meant to suggest that the traces were laid out manually using a CAD program, as opposed to auto-routed?
cityzen -
Perhaps by "hand drawn" they meant "hand taped," the more usual method for circuit layout. While I have done small boards with a photo-resist pen on the copper or a marker on a mylar mask, it was more usual and easier to use a strong black tape on the copper or the mask. It came in varying widths, and you could also buy stick-on or transfer pads for through-holes and sets of pads for ICs. When taping out stuff it was definitely easier to do straight lines than curves!
Note that some of the 2600 consoles had (very slightly) different lengths of screws, and putting them in wrong would tear up the traces on the board. http://www.atarimuseum.com/videogames/co...
The article you linked mentions "two sizes of self-tapping screw". Self-tapping screws were only used in the consoles with six switches on the front, from the first two production runs. The issue was resolved by the time those with four front switches were made, like the one used for illustration of this article.
Esa FUE mi primer consola y con esa aprendi ELECTRONICA yo la limpiaba y la reparaba …… Que buena epoca esa
Que?
12345678
I had a 2600 when I was a kid I loved it
Awesome! This console was the reason for my entrance into Electronics as a Technician.
Belle jouex classic
o meu nao esta ligando
The Playstation 3 comparison should include the fact that the 2600 came with controllers for two players (two joystick and two paddles) and a bundled game. Adding an extra controller and game would make the inflation-adjusted Playstation price nearly the same as the Atari.
Jonathan Kagle - Ответить
