Выберете то, что вам нужно
Видео обзор
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать iPad Mini 5, воспользуйтесь нашим сервисным руководством.
  1. iPad Mini 5 Teardown, iPad Mini 5 Teardown: шаг 1, изображение 1 из 3 iPad Mini 5 Teardown, iPad Mini 5 Teardown: шаг 1, изображение 2 из 3 iPad Mini 5 Teardown, iPad Mini 5 Teardown: шаг 1, изображение 3 из 3
    • This tablet may be mini, but it has some big specs:
    • 7.9-inch (diagonal), LED-backlit Retina True Tone display with 2048 × 1536 resolution (326 ppi)
    • A12 Bionic SoC with 64‑bit architecture and embedded M12 coprocessor
    • 8 MP rear camera + 7 MP FaceTime HD camera
    • Wi‑Fi (802.11a/b/g/n/ac) with dual channel (2.4 GHz and 5 GHz) and MIMO support + Bluetooth 5.0
    • 19.1 Wh rechargeable lithium-polymer battery
    • Three-axis gyro + accelerometer + barometer + ambient light sensor
    • Let's kick things off with an airport security view of the box, charger, and Lightning cable (hat tip to the gang at Creative Electron).
  2. iPad Mini 5 Teardown: шаг 2, изображение 1 из 3 iPad Mini 5 Teardown: шаг 2, изображение 2 из 3 iPad Mini 5 Teardown: шаг 2, изображение 3 из 3
    • From the outside, this new Mini looks exactly like a downsized version of the equally-new iPad Air.
    • Spoiler alert: judging by the X-rays, it's not a downsized new iPad Air. It looks exactly like an upgraded iPad Mini 4.
    • The new Air, meanwhile, is based on the last-generation iPad Pro 10.5". (Stay tuned for our Air teardown, coming in about a day.)
    • Meanwhile, Apple also sells the iPad 6 (or just "iPad"), which itself is a reworked version of the original iPad Air.
    • Did you get all that? Because we haven't even mentioned the latest iPad Pros yet. In fact, let's go ahead and not mention those.
    • We pull a cellular-capable iPad Mini 4 from the lab to confirm our suspicions. Headphone jack: check. Big bezels: check. Home button: check.
    • About the only exterior clue that gives away the new model is its model number, A2133—oh, and the loss of those regulatory markings on the back, which all live in software now.
    is the ipad mini 4 screen compatible with ipad mini 5 ?
    sportsandfitness - Ответить
  3. iPad Mini 5 Teardown: шаг 3, изображение 1 из 3 iPad Mini 5 Teardown: шаг 3, изображение 2 из 3 iPad Mini 5 Teardown: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    iOpener
    $19.99
    Купить
    • As much as we wish Apple would come up with a better approach to tablet construction (like they've done for phones, or like others have done for tablets), we're pretty sure we know how opening this one is going to go:
    • Heat.
    • Slash.
    • Repeat.
    • Once the Mini is shucked, we get our first peek at the tasty internals.
  4. iPad Mini 5 Teardown: шаг 4, изображение 1 из 2 iPad Mini 5 Teardown: шаг 4, изображение 2 из 2
    • After all that glue, we're treated to some less frustrating fasteners.
    • Knowing Apple's penchant for goofy screw heads, we brought our whole set of drivers. Thankfully this part of the Mini hasn't changed—we're just dealing with standard Phillips heads here.
    • Our drivers make short work of those screws and we remove the bracket covering the display and battery connectors ...
    • ... and it brings along a friend! Turns out the battery flex connector is now adhered to that cover bracket, automatically disconnecting the battery when the bracket is removed. Nifty!
    • Hopefully this will help fixers to not accidentally kill the backlight on their displays.
  5. iPad Mini 5 Teardown: шаг 5, изображение 1 из 3 iPad Mini 5 Teardown: шаг 5, изображение 2 из 3 iPad Mini 5 Teardown: шаг 5, изображение 3 из 3
    • Notice the clean lines and muted colors in Apple's foray into abstract art. The second image is extra abstract thanks to X-rays.
    • Let's channel our inner art critic and try to spot some differences between the newest Mini and its predecessor:
    • Different battery model, with updated (i.e. incompatible) connectors
    • Rated for 19.32 Wh, it matches the last Mini's, has less than the standard iPad's 32.9 Wh, and comes in a little over the Galaxy Note9's 15.4 Wh.
    • Upgraded front-facing camera module
    • Updated ambient light (True Tone) sensors
    • A migrated set of microphones
    • Here's a clean view with no markings, in case you want to spot the differences yourself.
  6. iPad Mini 5 Teardown: шаг 6, изображение 1 из 2 iPad Mini 5 Teardown: шаг 6, изображение 2 из 2
    • Despite their similar hardware, iPads continue to lag way, way behind iPhones in their construction—this home button being a perfect example. On iPhones this is an easy, elegant swap, but here it's still a mess of glue, even after all this time.
    • Elsewhere on this display, we blast the shields off and smoke out the chips underneath:
    • Parade Technologies DP815 Display Port timing controller (likely)
    • Texas Instruments TPS65195 clock level shifter
    • Texas Instruments TPS65144 LCD Bias w/ integrated gamma reference
    • Intersil ISL24879 precision programmable LCD reference voltage generator
    • STMicroelectronics M24C64-F 64 Kb Serial EEPROM memory
  7. iPad Mini 5 Teardown: шаг 7, изображение 1 из 3 iPad Mini 5 Teardown: шаг 7, изображение 2 из 3 iPad Mini 5 Teardown: шаг 7, изображение 3 из 3
    • This Mini inherits the 7 MP ƒ/2.2 front-facing camera setup we first saw in the 10.5-inch iPad Pro.
    • That's a pretty significant upgrade from the 1.2 MP sensor in the Mini 4, though the housing looks mostly the same.
    • With the cameras out of the way, we get a close look at the new upper microphone array, now centered near the selfie cam.
    • Next, the logic board comes free after a good struggle against the kragle underneath. (Why do iPads always feel like they're assembled by Lord Business?)
  8. iPad Mini 5 Teardown: шаг 8, изображение 1 из 3 iPad Mini 5 Teardown: шаг 8, изображение 2 из 3 iPad Mini 5 Teardown: шаг 8, изображение 3 из 3
    • Let's see what kind of silicon Apple managed to squeeze in here:
    • Apple APL1W81 A12 Bionic SoC, layered over Samsung K3UH4H40AM-MGCL 3 GB LPDDR4X DRAM
    • Toshiba TSB3243VD1190CHNA1 64 GB flash memory
    • Apple/USI 339S00551 Bluetooth/WiFi module
    • Broadcom BCM15900 touchscreen controller
    • Apple 343S00286-A0 and 343S00282-A0 power management ICs (left to right)
    • NXP Semiconductor CBTL1612A1 display port multiplexer
    • NXP Semiconductor 100VB27 (SN100V) NFC controller
    So with that charging chip (same as iPhone 8 and X according to google?) this thing should fast charge over USB 3?
    djschillz - Ответить
    Does anyone know with certainty that the Mini 5 will/will not fast charge up to 18W? Thanks
    Steve - Ответить
    what is that LIFD6 chip just above the processor?
    Ralph Hipps - Ответить
    Is cirrus logic chip in there ?
    Born Smith - Ответить
    What about Gps chip ? In usa I see on tech spec.Galileo sat, in Italy no…. why?
    argi.m - Ответить
  9. iPad Mini 5 Teardown: шаг 9, изображение 1 из 3 iPad Mini 5 Teardown: шаг 9, изображение 2 из 3 iPad Mini 5 Teardown: шаг 9, изображение 3 из 3
    • IC identification, continued:
    • Cirrus Logic CS42L83A audio codec
    • Cirrus Logic audio amplifier
    • Cypress Semiconductor CYPD2104 USB-C port controller
    • Bosch Sensortec accelerometer/gyroscope
    • Bosch Sensortec pressure sensor
    • AKM Semiconductor AK0991xx digital compass
  10. iPad Mini 5 Teardown: шаг 10, изображение 1 из 1
    • With this iPad Mini in pieces, we'll conclude our teardown! What did we learn?
    • The iPad Mini continues to be (mostly) its own entity—not quite a shrunken down iPad, nor a miniature iPad Air.
    • After a number of conflicting experiences ultimately leading up to this Mini's glued-in battery, we're officially not optimistic anymore about seeing adhesive pull tabs for iPad batteries.
    • That said, it's time to give this iPad a repairability score!
  11. Заключительные мысли
    • A single Phillips driver takes care of all the screws.
    • Many components are modular and can be replaced independently, but the Lightning port is soldered to the logic board.
    • Battery replacement is possible, but still unnecessarily difficult.
    • Gobs of adhesive hold many parts and cables in place, complicating all repairs.
    • Removing the home button is tough, and will be required for display replacement if you want to keep Touch ID functionality.
    Уровень ремонтопригодности
    2
    Ремонтопригодность 2из 10
    (10 легче всего ремонтировать)
16 Комментариев
This leaves me wondering what kind of chip is in the cellular model providing gigabit LTE.
Alex - Ответить
Like is it Intel? Probably Intel considering the current situations with Qualcomm.
jridder -
I have one, and it’s def Touch ID 2 - it’s so fast.
djschillz -
So it’s extremely similar to iPad mini 4. Is it harder to repair than iPad mini 4?
Aaron - Ответить
It's not going to be any harder to repair than the mini 4
Kevin Schneider -
You mentioned the front-facing camera. What about the rear-facing one? Which model is it from? No change from the mini 4?
John - Ответить
Is the screen compatible with the screen from iPad mini 4? Looks same or similar enough. Can you test it?
krupk4 - Ответить
Is the mini 5 Touch ID home button slightly positioned lower than mini 4? So old screen protector cannot aligned properly
Justin Lim - Ответить
There's NFC Controller inside? But without NFC antenna?
谣言似山 - Ответить
Touchscreen mini ipad 4 is compatiblible for mini 5 ?
Altielio - Ответить
is the same display on iPad mini 4?
Jesus Ruiz - Ответить
Does iPad Mini 5 Wifi version contains Digital Compass ? Technical specs. mentioned it does but no Compass apps and the accuracy is very bad, no way to re-calibrate.
Ricky - Ответить
Help my iPad screen is broken and touch is working
Should I screen replacement from aliexpress and fix it myself?
Jirawat Boonkumnerd - Ответить
I’d like to point out that the microphone placement by the selfie cam isn’t new for the 5. My 3 sitting next to me has them in that exact spot, due to it being a Wi-Fi only model. On the cellular model they are moved near the rear camera. Otherwise it’s about time this got an update, now to retire my 3.
Alex - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 103
За последние 30 дней: 474
За всё время: 105,715
