iPhone 8 Plus Home/Touch ID Sensor Replacement
Выберете то, что вам нужно
  1. iPhone 8 Plus Home/Touch ID Sensor Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 8 Plus Home/Touch ID Sensor Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. iPhone 8 Plus Home/Touch ID Sensor Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Спросите у FixBot
  4. iPhone 8 Plus Home/Touch ID Sensor Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  5. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 5, изображение 1 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 5, изображение 2 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 5, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Спросите у FixBot
  6. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 6, изображение 1 из 2 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 6, изображение 2 из 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  7. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 7, изображение 1 из 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
    Спросите у FixBot
  8. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 8, изображение 1 из 2 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 8, изображение 2 из 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Спросите у FixBot
  9. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 9, изображение 1 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 9, изображение 2 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 9, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick or other thin pry tool a few millimeters into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Спросите у FixBot
  10. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 10, изображение 1 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 10, изображение 2 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 10, изображение 3 из 3
    • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    Спросите у FixBot
  11. iPhone 8 Plus Home/Touch ID Sensor Replacement, Screen information: шаг 11, изображение 1 из 1
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
    Спросите у FixBot
  12. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 12, изображение 1 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 12, изображение 2 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 12, изображение 3 из 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Спросите у FixBot
  13. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 13, изображение 1 из 1
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    Спросите у FixBot
  14. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 14, изображение 1 из 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Спросите у FixBot
  15. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 15, изображение 1 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 15, изображение 2 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 15, изображение 3 из 3
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
    Спросите у FixBot
  16. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 16, изображение 1 из 2 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 16, изображение 2 из 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    Спросите у FixBot
  17. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 17, изображение 1 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 17, изображение 2 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 17, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Спросите у FixBot
  18. iPhone 8 Plus Home/Touch ID Sensor Replacement, Battery Disconnection: шаг 18, изображение 1 из 2 iPhone 8 Plus Home/Touch ID Sensor Replacement, Battery Disconnection: шаг 18, изображение 2 из 2
    Magnetic Project Mat
    $19.95
    • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • One 1.4 mm screw
    • One 2.7 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    Спросите у FixBot
  19. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 19, изображение 1 из 1
    • Remove the lower display cable bracket.
    Спросите у FixBot
  20. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 20, изображение 1 из 2 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 20, изображение 2 из 2
    • Use the point of a spudger to pry the battery connector up from its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Спросите у FixBot
  21. iPhone 8 Plus Home/Touch ID Sensor Replacement, Display Assembly: шаг 21, изображение 1 из 2 iPhone 8 Plus Home/Touch ID Sensor Replacement, Display Assembly: шаг 21, изображение 2 из 2
    • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    Спросите у FixBot
  22. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 22, изображение 1 из 2 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 22, изображение 2 из 2
    • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
    Спросите у FixBot
  23. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 23, изображение 1 из 2 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 23, изображение 2 из 2
    • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.0 mm screw
    • One 1.2 mm screw
    Спросите у FixBot
  24. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 24, изображение 1 из 1
    • Remove the bracket covering the front panel sensor assembly connector.
    Спросите у FixBot
  25. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 25, изображение 1 из 2 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 25, изображение 2 из 2
    • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
    Спросите у FixBot
  26. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 26, изображение 1 из 1
    Спросите у FixBot
  27. iPhone 8 Plus Home/Touch ID Sensor Replacement, Home/Touch ID Sensor: шаг 27, изображение 1 из 2 iPhone 8 Plus Home/Touch ID Sensor Replacement, Home/Touch ID Sensor: шаг 27, изображение 2 из 2
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.2 mm screw
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
    Спросите у FixBot
  28. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 28, изображение 1 из 1
    • Remove the bracket that secures the home/Touch ID sensor.
    Спросите у FixBot
  29. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 29, изображение 1 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 29, изображение 2 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 29, изображение 3 из 3
    • Pry under the left edge of the home button cable connector to disconnect it from its socket.
    • If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
    Спросите у FixBot
  30. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 30, изображение 1 из 1
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
    • Don't overheat the display. It should be slightly too hot to touch comfortably.
    Спросите у FixBot
  31. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 31, изображение 1 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 31, изображение 2 из 3 iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 31, изображение 3 из 3
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
    Спросите у FixBot
  32. iPhone 8 Plus Home/Touch ID Sensor Replacement: шаг 32, изображение 1 из 1
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display as shown.
    • Your replacement part may come with extra Y000 screws already installed near the Home Button. Remove the unnecessary screws so that you can reinstall the home button bracket.
    Спросите у FixBot
Заключение
If your replacement screen did not come with a front camera and sensor cable, follow these steps to transfer them over.
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
56 человек успешно провели ремонт по этому руководству.
Jeff Suovanen
Участник с: 08/06/13
453 554 Репутация
Автор 259 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 31 535 руководств
6 Комментарии к руководству
aiuto mi son cadute e quindi perso
sensore home/Touch ID Una vite da 1,2 mm Tre viti da 1,3 mm
dove le trovo?
Giovanni Giuffrida - Ответить Поделиться
ATTENTION: Don’t screw in that one screw over the home button too much, or the button breaks! I just found one proper explanation for it in this YouTube video (https://www.youtube.com/watch?v=rDVnp90a...). Basically, that one screw that goes over the Home button should not be tightened too much, so that the metal plate doesn't bend (which it did for me).
Manuele - Ответить Поделиться
This was truely helpful.
Josh Odeh - Ответить Поделиться
Anybody have the issue where the button works when the phone is in 2 pieces, but when you assemble the screen onto the phone body, the button no longer responds after a restart??
Power on phone while in 2 pieces -> home button is working
Attach screen to phone body -> home button is still working
Restart phone with phone assembled -> home button not responding
Morrious - Ответить Поделиться
Hallo Zusammen
Wird bei diesen Mikroschrauben nur das Gewinde gemessen oder die gesammte Schraube inkl. Schraubenkopf? Ich frage, weil mir die Schrauben des Homebutton weggespickt sind 1.2 und 1.3mm...
Danke
LG
alex delpiero - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 75
За последние 30 дней: 556
За всё время: 140,790
