Вики, созданная, благодаря помощи студентов
Эта вики выполнена отличной студенческой командой из нашей образовательной программы.
The camera will not turn on
It seems that you have tried everything, but your camera still will not turn on.
The battery is drained or has gone bad
If your camera has not been used in awhile, it is very possible that your batteries need to be replaced. If the batteries are rechargeable, try charging them. If the camera still does not turn on, try replacing the batteries with brand new ones.
The motherboard has gone bad
If the camera still does not turn on once you have tried recharging the batteries and/or replacing the batteries with brand new ones, your camera most likely has a bad motherboard. Though repairing the motherboard sounds difficult, it is a simple repair that you can do by following our step-by-step guide.
The camera does not remain charged long enough to take a picture or video
When taking a picture or video, the camera suddenly turns off because it will not hold a charge.
If your battery is drained or has gone bad, it needs replacement. If the batteries are rechargeable, try charging them. If the camera continues to shut off before you can take a picture or video, try replacing the batteries with brand new ones.
If the camera still continues to shut off before you can snap a picture or video once you have tried recharging the batteries and/or replacing them, your camera cannot hold a charge. It most likely has a bad motherboard. Replacing a broken motherboard can be solved by following our step-by-step guide.
The LCD screen is black
The pictures and videos you are shooting cannot be seen because your LCD screen has gone black.
The LCD screen has been cracked
The camera dropped and the screen cracked. Often, the screen will still work and it is just difficult to see past the cracked appearance; however the drop that caused the cracks could also be causing the screen to black out. In this case, the screen needs to be replaced with a new screen.
Your batteries need to be replaced. If the batteries are rechargeable, try charging them. If the camera continues to have a black, non-functioning screen, try replacing the batteries with brand new ones.
The camera has experienced total system failure
Total system failure has occurred with your camera. If your camera has not been dropped and you have tried replacing the batteries, it is likely that it has a bad motherboard. Though replacing the motherboard sounds difficult, it is a simple repair that you can do by following our step-by-by guide.
The pictures appear blurry
No matter how well you focus or how well you line up the shot, the pictures will not come out clear.
The outer lens is dirty
The lens is dirty and is affecting the quality of your pictures. The cause could be that over the life of the camera, a layer of dirt or other debris could have accumulated on the outer lens. No need to worry. Simply take a soft, slightly damp cloth and gently rub on the exterior of the lens.
The aperture unit has accumulated dust
Residue may have built up on the inner lenses inside the camera's aperture unit. You will need to install a new one by following our instructions.
The motherboard cannot determine what is focused
The motherboard is broken and cannot determine what is focused. If you have tried cleaning the lens and your pictures are still blurry, the motherboard may not be able to determine what is and is not a clear photo. If this is the case, you will need to replace the motherboard.
The buttons are sticky
You are trying to press the buttons on your camera to take a picture and zoom; however, the buttons will not depress.
The button is jammed
Dust, dirt, or other particulate matter has become lodged in the button enclosure and the button is no longer responsive. The button needs to be replaced.
16 Комментариев
The LCD screen has gone black. I can read the menu but I can't see anything from the lens on the screen. Can anyone shed some light on my situation?
tsweetness - Ответить
Did you fix it? I have the same problem
VINOD MOHANAN -
The LCD screen has gone black. I can see the menu but I can't see anything else. Does anyone know how to fix this problem? I did the reset option twice but nothing works.
No. I'm having the same problem with my Sony Cyber-shot D.SC.-HX1. I haven't dropped my camera. I haven't used it in a year because I was using my phone. I re-ordered new batteries and even though I see saved photos in the view, I cannot see anything but black when trying to take a photo. The camera does take photo's, but they are all black. Any help is appreciated. Thanks
Suzi Bay - Ответить
Did you fix it? I have the same problem with my cam
VINOD MOHANAN -
