iPhone 7 Plus Screen Replacement
Выберете то, что вам нужно
Видео обзор
  1. iPhone 7 Plus Screen Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Plus Screen Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 7 Plus Screen Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 7 Plus Screen Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 7 Plus Screen Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPhone 7 Plus Screen Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPhone 7 Plus Screen Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 7 Plus Screen Replacement: шаг 4, изображение 1 из 3 iPhone 7 Plus Screen Replacement: шаг 4, изображение 2 из 3 iPhone 7 Plus Screen Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 7 Plus Screen Replacement: шаг 5, изображение 1 из 2 iPhone 7 Plus Screen Replacement: шаг 5, изображение 2 из 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 7 Plus Screen Replacement, Heat the display: шаг 6, изображение 1 из 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  7. iPhone 7 Plus Screen Replacement, Separate the display: шаг 7, изображение 1 из 2 iPhone 7 Plus Screen Replacement, Separate the display: шаг 7, изображение 2 из 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  8. iPhone 7 Plus Screen Replacement: шаг 8, изображение 1 из 3 iPhone 7 Plus Screen Replacement: шаг 8, изображение 2 из 3 iPhone 7 Plus Screen Replacement: шаг 8, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 7 Plus Screen Replacement: шаг 9, изображение 1 из 3 iPhone 7 Plus Screen Replacement: шаг 9, изображение 2 из 3 iPhone 7 Plus Screen Replacement: шаг 9, изображение 3 из 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  10. iPhone 7 Plus Screen Replacement, Screen information: шаг 10, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  11. iPhone 7 Plus Screen Replacement: шаг 11, изображение 1 из 3 iPhone 7 Plus Screen Replacement: шаг 11, изображение 2 из 3 iPhone 7 Plus Screen Replacement: шаг 11, изображение 3 из 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  12. iPhone 7 Plus Screen Replacement: шаг 12, изображение 1 из 2 iPhone 7 Plus Screen Replacement: шаг 12, изображение 2 из 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  13. iPhone 7 Plus Screen Replacement: шаг 13, изображение 1 из 3 iPhone 7 Plus Screen Replacement: шаг 13, изображение 2 из 3 iPhone 7 Plus Screen Replacement: шаг 13, изображение 3 из 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  14. iPhone 7 Plus Screen Replacement: шаг 14, изображение 1 из 2 iPhone 7 Plus Screen Replacement: шаг 14, изображение 2 из 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  15. iPhone 7 Plus Screen Replacement: шаг 15, изображение 1 из 3 iPhone 7 Plus Screen Replacement: шаг 15, изображение 2 из 3 iPhone 7 Plus Screen Replacement: шаг 15, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  16. iPhone 7 Plus Screen Replacement, Battery Disconnection: шаг 16, изображение 1 из 1
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
  17. iPhone 7 Plus Screen Replacement: шаг 17, изображение 1 из 2 iPhone 7 Plus Screen Replacement: шаг 17, изображение 2 из 2
    • Remove the lower display cable bracket.
  18. iPhone 7 Plus Screen Replacement: шаг 18, изображение 1 из 3 iPhone 7 Plus Screen Replacement: шаг 18, изображение 2 из 3 iPhone 7 Plus Screen Replacement: шаг 18, изображение 3 из 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  19. iPhone 7 Plus Screen Replacement, Display Assembly: шаг 19, изображение 1 из 3 iPhone 7 Plus Screen Replacement, Display Assembly: шаг 19, изображение 2 из 3 iPhone 7 Plus Screen Replacement, Display Assembly: шаг 19, изображение 3 из 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  20. iPhone 7 Plus Screen Replacement: шаг 20, изображение 1 из 3 iPhone 7 Plus Screen Replacement: шаг 20, изображение 2 из 3 iPhone 7 Plus Screen Replacement: шаг 20, изображение 3 из 3
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  21. iPhone 7 Plus Screen Replacement: шаг 21, изображение 1 из 2 iPhone 7 Plus Screen Replacement: шаг 21, изображение 2 из 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  22. iPhone 7 Plus Screen Replacement: шаг 22, изображение 1 из 1
  23. iPhone 7 Plus Screen Replacement, Home/Touch ID Sensor: шаг 23, изображение 1 из 1
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.1 mm screw
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
  24. iPhone 7 Plus Screen Replacement: шаг 24, изображение 1 из 1
    • Remove the bracket that secures the home/Touch ID sensor.
  25. iPhone 7 Plus Screen Replacement: шаг 25, изображение 1 из 3 iPhone 7 Plus Screen Replacement: шаг 25, изображение 2 из 3 iPhone 7 Plus Screen Replacement: шаг 25, изображение 3 из 3
  26. iPhone 7 Plus Screen Replacement: шаг 26, изображение 1 из 2 iPhone 7 Plus Screen Replacement: шаг 26, изображение 2 из 2
    • Carefully pry up the underlying connector and move it out of the way of the home/Touch ID cable.
    • It's very easy to damage your iPhone during this step. Work slowly and take care where you pry with your tool. If you damage the Touch ID hardware, it can only be replaced by Apple.
    • If the connector doesn't pry up easily, use a hair dryer or iOpener to heat and soften the adhesive securing the connector, and then try again.
    • Don't try to detach the connector completely—simply flip it up slightly so that the underlying home/Touch ID sensor cable can be removed.
  27. iPhone 7 Plus Screen Replacement: шаг 27, изображение 1 из 1
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
  28. iPhone 7 Plus Screen Replacement: шаг 28, изображение 1 из 3 iPhone 7 Plus Screen Replacement: шаг 28, изображение 2 из 3 iPhone 7 Plus Screen Replacement: шаг 28, изображение 3 из 3
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
  29. iPhone 7 Plus Screen Replacement: шаг 29, изображение 1 из 1
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display.
    • Your replacement part may come with an extra Y000 screw already installed right of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
    • Follow this guide to install replacement display adhesive on your screen.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
616 участников успешно повторили данное руководство.
Paige Reisman
Участник с: 04/07/14
23 586 Репутация
Автор 15 руководств
60 Комментариев
Only the glass is broken on my screen. I don't need a new digitizer. Is there a way to just replace the glass? Seems like that would be much cheaper. Thanks!
Justin Brockbank - Ответить
Unfortunately, by the nature of the technology, cracked glass likely means your digitizer is out of commission (does touch still register on the cracked screen?). Below that is the LCD, and that might not be broken (if the image is fine, then the LCD is likely fine). The problem is that these components are VERY VERY difficult to separate. This makes the individual replacements a nightmare. I hate to say anything is impossible, but separating these components will feel impossible without expensive tools and extensive knowledge. It will also likely end in a mess of broken components. When there is a will, there is a way. But the separation project will demand a lot of will.
Scott Havard -
Our store is having trouble with the earpiece speaker working after screen repair on just the 7 Plus, not with the 7. We have tried different techniques and still get figure what we are doing wrong. Has anyone else had this problem and know the solution?
Joe Cox - Ответить
My earpiece speaker also won't work with new screen... this is frustrating. Any solution
Ben -
There are some connections for the earpiece speaker that can be a little tricky to get properly connected during reassembly. If you look at the third photo in step 22 of the iPhone 7 Plus teardown you can see four copper pads on the cable, and four protruding copper connections on the speaker. For starters, make sure that these are all clean. When reassembling, make sure that the metal pads on the cable firmly touch the metal pins on the speaker. These are actually electrical connections, and are a little tougher to seat properly because they don't snap in like press or ZIF connectors. If the metal is all lined up and pressed against each other, then electricity should be flowing and sound should result! If the earpiece speaker was not removed and this guide was followed as is, it is most likely an issue with the connectors in step 19 of this guide.
Scott Havard -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 45
За последние 7 дней: 298
За последние 30 дней: 1,493
За всё время: 613,674
