Two beeps and black screen.
I have the same problem as Angela but my screen is always black, when I try to reset it (by holding the menu and select button for 6sec) it just powers off and back on but still gives the black screen. Then it beebs 2 times, just like Angela's I suppose. I just tried to reset it via iTunes but it still shows a black screen. I can hear the clicks when I use the click wheel. What do I do ?
Greetz James
Это хороший вопрос?
Счет 2
1 Комментарий
My iPod will not turn on I put it on the changer an it beeps 2 times dose that mean its changing
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
jamesschelfaut, there are a few possibilities, but they all require you to disassemble your iPod. It could be loose ribbon cables, corroded connectors, a bad LCD and/or bad backlight circuit. I would check it in that order. Here are the guides to work on it. Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
jamesschelfaut буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 33
За все время: 9,854
