Беспроводной контроллер Xbox 360, выпущенный 22 ноября 2005 года, является основным игровым контроллером для домашней игровой консоли Microsoft Xbox 360.
Central guide button has jammed
Right heres the problem, the guide button in my limited editionxbox 360 controller has jammed in place an now trys turning off the xbox every few minutes. I've not spilt anything on it, this is the only controller I've got thats suffered this problem, I've tried cleaning it with a mild alcohol cleaner which did nothing I also tried giving it a quick blast with compressed air which did nothing, is their anything I can do to fix this without soldering.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
James Roff, take a look at this guide. Clean all components with alcohol, all rubber and plastic components with mild detergent,. Take a look at the corresponding ends and see if you can find where it jams.
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
Cheers I'll give it a shot and get back to you on the results
из
Had to use a fine glass paper to smooth the guide button as it was rough and stocking but apart from that your advice was spot on =) cheers
из
Thank you for accepting my answer. Best of luck to you.
из
Добавьте свой ответ
James Roff буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 18
За все время: 7,299
