Add Boot Option using Insydeh20 setup utility
Hi,
I have a Dell Inspiron 7520 (i7 processor) laptop. When I tried to start my system it showed the spinning icon, and after few seconds, it showed me a blue screen with the following error message:
"Your PC ran into a problem and needs to restart. We're just collecting some error info, and then we'll restart for you".
Once it shows the above message, the system restarts and then repeats the same process of showing the same error message and restarting. This keeps happening in a loop.
The software running in the BIOS is Insydeh20 setup utility.
I managed to get a copy of Windows 8 on a USB drive. In order to boot from the USB, I got into the Bios (using F2) and tried to "Add boot option," as there were no other boot options present. When I tried to do that, it asked me to provide a name. I entered "USB". It then added it & allowed me to edit properties of this option. When I tried to edit the property, it asked for File system path. Because this is a USB drive, I do not have a clue as to what this value should be & how to set this USB drive as the first priority.
Any instructions on how to set the file system path for the USB drive and how to set it as the first priority will be greatly appreciated.
Thank you.
Это хороший вопрос?
11 Комментариев
Did you make your USB drive bootable when you copied Win8?
из oldturkey03 Поделиться
I have 7520 and I can't boot from USB pen drive.
Dear oldturkey03! The problem isn't the booting capable of pen drive. The real problem is a BIOS of 7520, because we can't set the boot device to USB.
из sandorh Поделиться
Thank you for this.
из Jake West Поделиться
Make it(USB) first in BIOS or just press f12 to acces boot menu make sure there is no other media before USB flash nice to see that it`s solved.
из Janis Поделиться
This trick is also not working
из Abhishek sahu Поделиться
Показать ещё 6 комментариев
