Цифровая камера PowerShot SD1000 Digital Elph оснащена 7,1-мегапиксельной матрицей и 3-кратным оптическим зумом
"No Memory Card Error" What next?
Hello Everyone. I am new here so bare with me.
I tried all the "WONDERFUL' toothpick tricks and what not, to no avail. I still do not have successful results.
I disassembled the camera completely.
I am attaching some pictures to see if anyone sees something that I am missing. Something I am overlooking. Also, is there an option to fix the memory card slot…ie. Soldering or replacing it?
Your comments are welcomed and appreciated
Thanks
Это хороший вопрос?
Счет 1
1 Комментарий
I assume that you originally tried more than one card, just to rule that out as the cause. You can replace the card reader, as long as you find a proper replacement. This one should be a standard one, so I would try to scrounge a broken camera and replace it. the soldering will be somewhat tricky and will require a bit of practice :-) but it can be done.
из
Добавить комментарий
2 Ответов
Выбранное решение
One of the contact pins are probably bent or mashed in.
The way SD card slots are soldered to the PCB makes it nearly impossible to replace. Machines, not man solders this stuff together when it's made.
Your best bet is to get a good main PCB from a junker SD1000 camera on eBay.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thank you very much for responding.
I went ahead and purchased a new PCB on Ebay.
I really wanted to try to replace the memory card slot but as you said, it can be really tricky and besides, I did not have the correct solder pin.
из
Mission Accomplished.
What shall I get myself into next?
Счет 1
2 Комментариев:
Excellent, great job.
из
Thank you very much. It was interesting.
из
Добавьте свой ответ
Janet буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 8
За последние 30 дней: 31
За всё время: 2,604
