10,1-дюймовый планшетный компьютер, выпущенный в декабре 2011 года. Оснащен четырехъядерным процессором, Wi-Fi, GPS и подключаемой клавиатурой.
Screen problem after water drop
I dropped my Prime into bathtub and dried it afterwards. Overall it works ok, but half of the screen is covered with color lines that sometimes change to black or other single color, sometimes they disappear but the image is fuzzy in that part of screen. Digitizer works ok. Tried disconnect and connect screen - doesn't help.
What part should I replace? Screen? Motherboard?
Photos:
http://s017.radikal.ru/i435/1301/cf/a4ee...
http://s019.radikal.ru/i640/1301/b9/5299...
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Stanislav Polyakov, the very first thing I suggest is that you clean your Asus. Disassemble it and clean all of the parts with +90% isopropyl alcohol, do not forget the cable ends and the connectors. Replace the battery. Reason for all of this is to avoid corrosion failure later on, and it will corroded:) once you get all this done, reassemble and re-evaluate. It does look like you will at least need a new LCD. Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thanks for your feedback. I will clean it and see the result.
из
Добавьте свой ответ
Stanislav Polyakov буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 30
За все время: 983
