Встроенная технология Beats Audio™ обеспечивает бескомпромиссное звучание студийного качества для вашей музыки, видео и игр. Это мощное универсальное устройство с двухъядерным процессором, великолепным и четким 4-дюймовым дисплеем, а также лучшей в своем классе камерой
Cracked touch screen panel
My sister has a HTC Desire X phone.
Link: http://www.htc.com/nl/smartphones/htc-de...
It has a crack in the top screen only. The display itself is not damaged.
Can i replace the top screen. Where can i buy the parts?
Thanks in advance.
Это хороший вопрос?
Счет 1
5 Комментариев
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts.Thanks-Kiran
из
am using htc dsire x,my power button is totaly damagd,how to replaced the buttn....
из
Display and touch is damaged
из
My phone modle is htc desire.can I replace only a top screen glass.bcz touch with lcd display 's cost is high
из
My phone is htc desire x in which display has been cracked but touch s working.. Nd battery has a poor problem.. Can u replace battery nd display????
из
Добавить комментарий
9 Ответов
Выбранное решение
The screen can be replaced.
you can find the part on ebay:
http://www.ebay.com/itm/Touch-Screen-Dig...
cheers
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
из
Наиболее полезный ответ
You will need an lcd separator machine to separate the lcd from the glass as they are glued together and it needs to be put on a special hot plate. Tutorial and lcd separator machine reviews can be found at www.lcdseparatormachines.com if your interested..
Счет 1
1 Комментарий:
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts...pls hlp me..
Michael
из
Be carefull! Hade the same problem with my sisters phone. I first tried to replace the Digitizer Glas, but its full glued on the LCD screen when I tried to seperate both the LCD broke. You have to replace the whole display unit. I bought them from ebay. Didn't find it on ebay.com but on the german site. It's about 90€
http://www.ebay.de/itm/Original-HTC-Desi...
Even this is the whole TOP-Unit it was still not very easy.
Hope I could help!
Счет 0
Hello
I´ve found it on ebay more cheaper.
http://www.ebay.es/itm/380739140385?ssPa...
I´m waiting for receive it and create a guide to all of you!
Счет 0
1 Комментарий:
i needed a new glass for mine which is a htc desire 310 and found my glass on ebay it's coming form hong kong
из
hi, yes be careful , Bernhard is right the digitizer glass is stuck glued with the lcd screen and it broke with me as well so i needed to change the whole display unit. i found it on ebay and it's cheap :
http://www.ebay.com.au/itm/for-HTC-Desir...
i ordered it and still waiting for it
Счет 0
Had anyone got some kind of repair-guide?
I only found this video:
https://www.youtube.com/watch?v=hzRsLDah...
Счет 0
1 Комментарий:
Hello, I´m working on a repair guide, hope to finish it on this weekend.
из
Did anyone bought some not original lcd and glass replacer?
I'm not sure if they are worth anything.
Счет 0
1 Комментарий:
Hello, yes, I have bought 2 lcd+touch non original ( but with the HTC logo) and they works fine. The point is to glue properly the piece to the phone, because sometimes it comes out.
из
how to stick the digitizer to the display\front pannel
.please help
mine is not sticking
i cleaned it with glass spray also
Счет 0
what you have to do is heat the screen up with a hair drier or hot blower and then remove the screen
Счет 0
Добавьте свой ответ
[deleted] буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 24,609
