The Skullcandy Skullcrushers Subwoofer Stereo Headphones in Black Pinstripe will literally pump the music right into your head! These power packing headphones feature an adjustable in-line bass amplifier and speakers with industry first built-in vibrating subwoofers. You can adjust the amount of bass effect with the in-line control wheel.
The left side of subwoofer
Hello i have to repair the left side of subwoofer in skullcrushers, and there is a question:
the subwoofer has 4 slots:
"LV+"
"LV-"
"RV+"
"RV-"
which of them should be paired with following cables:
"red-blue"
"red-gold"
"Green"
"blue-gold"
Это хороший вопрос?
Счет 2
2 Комментариев
Perhaps you could take apart the right side and see which ones match there (from my experience in audio, they should be exactly the same)? Bonus Internet points if you make a guide for it :)
из
Добавить комментарий
1 ответ
Выбранное решение
bartek94to, attached image is what I come up with on the opposite end. Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 2
4 Комментариев:
I did it like you had wrote me. But i can't even hear any bass : | maybe this subwoofer is just broken
из
Try to bypass and go right for the speakers. See if that makes a difference.
из
i don't realy know what do you mean : p and i am sure that i couldn't do that, cuz i am novice : | Have you got skype?
из
Try to bypass the amp. You will need the end that comes from the jack. See the repair 3.5mm jack on the device page Repairing Skullcandy SCS-SCBP SKULLCRUSHERS 3.5mm plug Connect Gold, Blue Gold RV- and LV- Red/Green to ground, L+Blue and LV+Green to the left, and R+ Red and Red/Gold RV+ to the right. sorry, can't Skype until I get off work. My Skype ID is in my profile.
из
Добавьте свой ответ
bartek94to буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 21
За всё время: 1,289
