Информация о ремонте и руководства для пятого поколения iPhone. Модель: A1387
Small component broken from the logic board
Some of the small components of the logic board of an iPhone 4S are gone. It gives problems during charging. They are pointed with an arrow on the picture. What are those? Can I solve this problem by bridge the contact points? Thanks in advance.
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
Gauthier Top, I marked the components in numerical order. They are a follows.
1. C293 100PF 5% 16 V NP0-C0G Capacitor
2. R153 0.00 0% 1/32W Resistor
part of BATTERY_NTC circuit
3. R61 0.00 0% 1/32W Resistor
4. C300 100PF 5% 16 V NP0-C0G Capacitor
part of BATTERY_SWI circuit
You should get away by bridging the resistors, but I would not bridge the caps. Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 4
5 Комментариев:
It worked. Thank you very much!
из
you are welcome. Thanks for accepting my answer.
из
where can i get those Capacitor and Resistor
из
@Rahul BJ, depends on where you are located. Mouser.com Digikey.com and many other places should have those.
из
Yes they are. The 0 value resistors are actually just jumpers.
из
Добавьте свой ответ
Gauthier буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 7,894
