HTC One (кодовое имя M7) — флагманский смартфон HTC 2013 года. Он отличается цельным алюминиевым корпусом, большими двойными фронтальными динамиками и 4,7-дюймовым дисплеем с разрешением 1080p.
How to fix the cracked screen?
My screen isn't shattered per say but it has a crack at the point of impact. Then the cracks become less visiable as it goes away then leads to the end of the screen. I know that it is nearly impossible to get inside of the HTC One much less fix the screen. Any help would be great.
Это хороший вопрос?
Счет 4
1 Комментарий
Thanks i'll let you know how it goes
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Connor Dempsey, use this teardown to give you an idea of what is involved. The display assembly isright here. Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
not quite sure why this was voted down. Just because somebody does not like it, does not make it a wrong.
из
alcs99 gave you the down vote. I'll up vote to cancel.
из
Thank you Sir. Not quite sure why alcs99 would do so. I would appreciate if people would at least say why they downvote an answer.
из
No disrespect guys! In my comment I hope I explained it well enough why I gave this comment a down vote. The iFixit staff's method of pulling it apart is not the way to do it and in my guide I show the correct way to do it. Much love and keep on fixing!
из
Do not follow ifixit's teardown, the method they used to open the phone to get at the internals is not the best way to do it. I posted a guide on repairing the screen with links to videos on how to properly open the phone and remove the back cover.
Замена дисплейного модуля HTC One
Счет 0
Добавьте свой ответ
Connor Dempsey буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 7
За последние 30 дней: 21
За всё время: 9,937
