The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
200вопросов Показать все
Water damaged phone, turns on but screen is black
Just recently, I dropped my phone in water, panicked and took battery and such out and dried the pieces and placed them in rice. I took it out and found out that my phone can turn on, receive notifications and all, but my screen won't turn on and remains black. I went to Sprint store, told me that they do not look at water-damaged phones... What are my options? The phone minus the screen is working perfectly and i would hate to buy a new phone.
Это хороший вопрос?
Оценка 33
1 Комментарий
I have this problem too, infact I have replaced the screen yet the phone is still blury with continuous lines across the screen. Please help me its a Samsung A32 less than 5 months.
из
Добавить комментарий
7 Ответов
Выбранное решение
David, Probable faulty display. Rice would have been of very little use and will not stop the corrosion that is happening in the phone. Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Samsung Galaxy S II Teardown
Electronics Water Damage
Был ли этот ответ полезен?
Оценка 8
7 Комментариев:
I have the same problem only mine is stuck on lock screen in talkback mode and won't respond . Same fix right?
из
Mine is the same scenario but my gadget is a tablet (Huawei MediapadT3 to be exact) I dropped it in water with soap, I didn't have the time to turn it off because the screen was black at that time and the tablet was not openable, I put it in rice for 2 days now, the tablet turns on but the screen is black, I don't know how to solve this
из
Me too i can only interact through the power button and nothing else. it's life my phone is not touch screen anymore... send tips and help please!
из
when i tried this, i got shocked :/
из
My phone is working but I can't see a human face they all look like negatives
из
Показать 2 больше комментариев
Well if your puting it in rice you might aswel just boil the phone and eat it as rice does absolutely nothing.very bad idea.
The phone needa opened up and washed with ISO alcohol then dryed,then turn on if you can only hear sound then it's possible that you need a new screen
Оценка 5
5 Комментариев:
Actually rice is a very good idea. Rice will suck out all of the moisture in the phone. its saved many phones of mine.
из
Well, if rice does nothing, then it's neither a bad nor a good idea... ;-)
из
that's what you think Elyssa but the truth is you have been lucky
из
Rice has helped me in the past so no, rice isn't useless or a bad idea thats just another person opinion. (Rice absorbs the moisture) what do you think people did before iso alcohol etc was created.........
из
Isopropyl alcohol was invented in 1920, so it's been here throughout the lifetime of modern electronic devices that might require cleaning and/or moisture mitigation. And silica gel, a much better solution to absorbing moisture than rice, has been around since the 1640s.
из
Phone might need a new LCD or the connector on the board has corrosion on it.
Оценка 3
4 Комментариев:
So I would need to go to one of those local repair stores to fix it?
из
Unless you want to take it apart yourself and clean it. I would start with a distilled water and baking soda mixture and gently scrub the board with a soft toothbrush and clean it really good. Make sure the LCD connector and flex cable for the LCD are clean. If that still doesn't work you either have board damage with the traces on the board and backlight issues or the LCD is toast and needs replaced. You can take it to a shop if you prefer.
из
But where is that located? Would i have to go over my screen or take the screen apart?
из
I have Samsung S 10 5g I made 3 videos with it in the pool the phone was working perfectly but after some time when I put the phone on charging its screen go black as dead. Its working in the background I can receive message and call anyone using Bixby but phone is just blacked. What should I do with that.
из
Hi David, before continuing reading this: Remove the battery as soon as possible and DO NOT CHARGE!
If a device is exhibiting symptoms of water damage the first step should be opening the device up to just double check that there isn't water still in it, shorting something out. (I have opened a phone up that got wet and was dried months ago, and still had water in it on the motherboard.)
1) Open it up, if water is there disconnect all power sources (including battery if possible), 2) next remove the water, (see footnote 1) this can be accomplished by drying with a hair dryer (not on high), 3: next put in a bag with some dessicants (see footnote 2) for 2-7 days, reassemble and voila!
Footnote 1: an optional but highly recommended step here is to pour 97% isopropyl alcohol in the device (but try not to pour on a screen, it can mess with adhesives) the benefit of this is the alcohol will often displace the water, meaning you now have a device that is now soaked in alcohol, still not ideal but way better because alcohol evaporates faster than water and is less corrosive)
Footnote 2: those little bags in food that say do not eat, can be purchased on amazon for cheap, for example: https://www.amazon.com/10g-Silica-Gel-De...
Оценка 3
1 Комментарий:
An a51 you have to turn it off by pulling the screen down no way can I do that because I cant see it
из
Open The Case Of Your Phone, Then Clean The Substances With A Thin Brush And Check If Its Now Working....
If Not, Proceed To These Steps
1.Shutdown Your Phone Let It Rest 2 Minutes.
2.Open Case
3. Remove Battery
4. Unscrew To Open The Board Processing Your Phone
5.Remove The Board
6.Reheat It With Heat Gun In 300 Degrees Celsius ( Be Careful On What You Going To Heat On Then, Kindly Revert The Steps
It Should Be Working Now.... If Not, Replacement May Be Needing
Its No Software Or Any Spy/Mal/Wares, Its Hardware
cheers, Erol
-Microsoft Community
Оценка 2
1 Комментарий:
My phone s10e drop in water damage
из
You have to change the display as same problem occurs in my Samsung Galaxy A70 phone and sensors are fully in operation even the touch panel in my my phone is working as i can receives the calls too but the display is dead might be due to moisture in the LCD as i tried every step and search everywhere none of them helps.
Оценка 1
It's the backlight that's bad. If you flash a torchlight on the screen when the phone is turned on you'll see that the LCD is working fine. You'll need to peal the screen with a heat gun and work on the backlight bulbs
Оценка 0
Добавьте свой ответ
David будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 72
За последние 7 дней: 579
За последние 30 дней: 2,603
За всё время: 280,840
