T-Mobile G1 — первый смартфон, выпущенный на рынок с мобильной операционной системой Android. Дата выхода: сентябрь 2008 года.
Why does my camera/camcorder application force close?
I have rooted G1 running the latest Cyanogen 4.2.3.1. Unfortunately, my camera/camcorder app force closes and refuses to open. I have wiped, reformated the SD, restored to stock G1 ROM, even went as far as trying another ROM thats not Cyanogen (*GASP*), but everytime it force closes. I am thinking it might be a hardware problem, but I'm not sure. Help!
Это хороший вопрос?
Счет 4
5 Комментариев
Are you running 1.5 or 1.6?
из
I'm running CyanogenMod 4.2.5 which is based off of Donut 1.6.
из
Normally this should be asked as a comment, but I'll hold off on down-voting you since you don't have the rep for commenting.
из
sorry, i'm new, just got the code today, and don't understand this system entirely
из
try reheating the i.c around the camera,i repair phones fyi
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
This intrigued me so I went into study mode. All I can say is I do not have an answer. The cam force closes even when phone is restored to T-mob stock configuration?
Help per my reading:
1. http://twitter.com/cyanogen
2. http://wiki.cyanogenmod.com/index.php/Ma...
3. http://forum.xda-developers.com/showthre...
good luck.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
The cam does force close when the phone is restored to stock configuration. I have a feeling that its a hardware related issue at this point.
из
I'd assume then its a cyanogen bug, the latest ROM is not 100% compatible with 1.6, try a complete restore to the original rom and it should probably work.
Счет 2
it sounds like it can't find the files in order to run
check and see if you accidentally moved or deleted some of the files
Счет 1
update software of camera
Счет 0
After clicking images, images are shown reverse
Счет 0
Добавьте свой ответ
Walter Galan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За все время: 7,987
