front light does not come on
hi
small amount of tea has been poured on nokia E90,,it has been working after some spray repair,only the front light does not come on?
What needs to be repaired?
thanks for your help
abi shahnazi
Это хороший вопрос?
hi
abi shahnazi
Это хороший вопрос?
Hi,
If you have problem with the light on the LCD, check first the connector between LCD and board. Because you have more power consumption through the pin for light may be you have burned, broken line. Second: you can have problem with the screen. Third: if you have problem with main board you must find LCD light line from schematic diagram.
Regards.
Был ли этот ответ полезен?
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 14
За всё время: 633
