Руководства по ремонту аппаратов и попкорниц.
Popcorn machine not turning on.
Are there any fuses that would keep the machine from getting power? Where would it be located on "the classic 16 pop" machine.
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
If you're talking about the Paragon Classic Pop, I don't see any evidence of it having a fuse (in the spare parts list). If the machine has no power at all (ie. heat lamp doesn't turn on, kettle doesn't warm up, motor doesn't turn) I would first check the outlet to make sure it's working then work your way into the machine with a voltmeter, checking each connection to see where the current flow stops. It could be as simple as a bad power switch.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Claudius буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 23
За все время: 7,171
