Руководства по ремонту мобильных телефонов производства компании Micromax.
Wifi Not Connect Mobile
I have recently purchased Micromax Canvas Nitro A310. Since the unboxing, I am facing wifi issue. For the first time after first switch on I was able to connect to wifi, but to my surprise after sometime i can't access internet though wifi is connected. I have no problem with wifi network as my another Samsung phone and laptop has no connection or access problem. Then i tried to connect the wifi after doing "forget password", but after I retype the password it shows "connecting", and sometimes "obtaining IP addresses", but never actually getting connected. For all I have to do for connection is to reboot the phone, and it automatically connects to wifi without even any need of typing the password.
Please help resolve this issue. I have heard the customer support is really bad for Micromax.
Это хороший вопрос?
Счет 27
35 Комментариев
Hi Senthil,
Have you fixed the issue?
из Поделиться
hai sivamani
wifi and blooth not connecting in one month plz help me
из Поделиться
wi fi authentication problem plz help me sir
из Поделиться
Plz help me my micromax bolt q338 not get on
I resorted it
Restoring process takes a long time so I removed it bettery and refix bettery
Afterwards it doesn't get on
It shows only checking connection
I connected WiFi also but it shows only checking connection
Plz help me how my mobile get on fully
Now it on partially so plz help me
из Поделиться
I am also facing the same problem with Micromax S301 .whenever i connect it says "Save and secured" then i enters the password but it didnt connect.plz tell me the solution
из Поделиться
Показать ещё 30 комментариев
Добавить комментарий
15 Ответов
Наиболее полезный ответ
This problem is clearly associated with the mobile's MAC address. You can FIX it by simply changing Mobile's MAC address. None other trick can solve this. Not even firmware flash. Because MAC will be remain unchanged after Stock ROM flash. Here is a good tutorial by androidmtk.com
https://androidmtk.com/how-to-use-writei...
Changes have to be made in STEP 6 of the tutorial.
  1. Untick IMEI1, IMEI2, IMEI3, IMEI4 (AS YOU NEED TO CHANGE WIFI MAC ONLY)
  2. Tick WIFI Mac Address
  3. Tick Generate WIFI Mac Addr. Automatically
  4. click Save.
Now click on WRITE button and you are all done.
NOTES:
If computer is not detecting your phone then:
  1. In windows 7 and above you may need to enable TEST MODE in CMD before installing SPD USB and Modem drivers.
  2. You may also need to disable signed driver enforcement in windows advance boot options.
  3. connect your phone in switch off mode only along with battery.
Still having problem??
feel free to mail me at shaunakpandey@gmail.com or Whatsapp me at +917355355687
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
subratamondal1idea@gmail.com
из Поделиться
из Поделиться
you can solve this problem with three methods.
1. go wlan(wi-fi) settings select wifi connection which you want to connect enter right password..
after that go to ip settings and switch it from DHCP to static
after that enter the valid information (your ip,getway,prefix lenth
=24, Dns (Your Dns) ,Dns (same your getway) then save your settings.
switch off or reboot your phone. hope it will fix your issue.
or
2.turn off your device and turn it on with recorvery mode by pressing power nad volume + key same time.. then by pressing volume keys select clear emmc option for hard reset your device. clear delvik cache. clear cache also. after that reboot your device by using reboot option from recovery menu. try rebooting may be it'll fix your issue.
3. you can also fix this problem by updating your device from setting>about phone> system update(after update reboot your phone and wait for automatic restart.
(note. make sure you have a working internet connection with mobile data connection.)
you can also root your device using kingroot app after that install cwm recovery or fhiz touch recovery. and download fix wifi zip from xda devloper and flash it from recovery mode by using cwm or phiz recovery.
Счет 1
Micromax bolt s301 me wifi connect nahi ho raha hai
Update (06/21/2017)
Micromax bolt s301 me wifi connect nahi jo raha hai
Счет 1
1 Комментарий:
из Поделиться
Wi-Fi calling Micromax Bharat Sarkar setting
Счет 1
Hello everyone,
i got solution of this problem, i have checked wifi setting and it is get ip which was on in range of my network thats why it is connecting and not working.
so i have change it (modify ) and reboot mobile and checked .....it is working fine for me now
No need to update your mobile or do anything just check your wifi setting and mobile wifi setting.....
thanks
Pravin
Счет 0
2 Комментариев:
can you please emal me at racoptic@gmail.com as how u fixed it?
из Поделиться
me too at kediakrishna65@gmail.com
из Поделиться
And the trick that works here is that you have to try to enable the data connection on your phone and when you fail just restart your phone and wait for sometime till full range of the mobile network is show on your phone and then you should try again to enable the data pack.This time you will have no difficulty.
Have a nice day~~~
Счет 0
1 Комментарий:
@ VSGK ........Do you advise to take a Data Connection and forget about WIFI connection ??
из Поделиться
Check to see if you may have turned on the airplane mode accidentally. Also, try turning it off completely and then on and try to hook up the wifi. Sometimes slow internet speed will keep bumping it off the wifi. The will happen more if you have several devices using the same slow connection. Good luck.
Счет 0
i was facing same problem but i did something i hope it will work for you too,at first try to make cell in flight mode and now type your wifi password but make sure if password 's first letter is capital or lowercase,it worked for me, good luck
Счет 0
please download wifi fix flash zip from internet according to your phone and install phiz touch recovery .. reboot to recovery and flash the wifi fix zip from sd card in recovery mode.
you can also change the wifi connection setting DHCP to static and enter the ip ,getaway and dns. enjoy :)
Счет 0
Micromax S301 has wifi connecting issues...Just take it to any Authorised Service Centre and ask them to write the Mac address....Voila....Problem Resolved.
Счет 0
micromax bolt phone wifi open connecet after 2 sec again close wiy
Счет 0
You can even connect wifi without passwordusing some tricks and then you won't face this issue
Счет 0
or
Счет 0
My WiFi networks not connected
Счет 0
Wi-Fi calling Micromax setting
Update (01/20/2020)
Счет 0
1 Комментарий:
из Поделиться
Добавьте свой ответ
Senthil буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 21
За все время: 46,744
