Портативный внешний жесткий диск Western Digital My Passport с интерфейсом USB 3.0.
My passport fails initializing
My passport 1TB ran for more than a year under windows 7,8 and actually 8.1, but suddenly stopped. it loads the drivers but doesn't appear in the explorer. when I start the disk management it indicates that the second disk (my passport) must initialize. but it fails.
it appears in the device windows , just doesn't start (or initialize). I even tried the refrigerator trick, nothing
I've also tried several data recover progs, recuva , testdisk, easyus, wondershare WAC, etc, they all fail to see the external drive.
there must be a program that can go through , any ideas?
thanks, Jim
Это хороший вопрос?
Счет 20
6 Комментариев
Just tried R-Studio, it sees the disk, but cant read it
из Поделиться
I was able to see the data inside the HDD with a linux version included in the Hiren's 15.2 CD also i could copy some files I needed but with 0 KB no luck yet, still working on it.
из Поделиться
2tb western digital my book, same problem, R-Studio brings up error 1117. Spent 3 days now trying to recover
из Поделиться
This problem is also with me too
из Поделиться
Hello, one could solve it?
из Поделиться
Показать ещё 1 комментарий
Добавить комментарий
8 Ответов
Выбранное решение
This may still be true. Try wiping the drive on a Mac and use the "write zeros" option. Used to be that if the boot blocks on an IBM went bad it was unusable with Windows but can be fixed on a Mac.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
there was some data that I would have liked to recover there. but if there's no other way. will try it as a last option. tnxz
из Поделиться
@mayer I fear that won't work on a Passport. These are custom amalgamations of a SATA and USB port. The enclosure itself is the drive. You can't even take it out and put it in another enclosure.
из Поделиться
The only 2 possible suggestions that may work are:
a) Solder on a new USB port.
b) Find a logic board for the matching drive. Hopefully you can find one with a SATA connection.
If you can get a working SATA port, then recovering may be possible.
Счет 1
this problem can't fix by any software...
you must repair the hardware of your WD HDD !!!
Счет 0
HOW can I repair hardware in a hdd??!! You need highly specialized equipment
Счет 0
Счет 0
same whith me sombody can help please?
Thank you
Счет 0
Hi Everyone,
this problem is because of firmware corruption of WD Hard disk drive that must be solve by Hard Repair Equipment like a PC3K ( a expensive hard repair hardware! ) but you can give your Western Digital hard disk to a HDD Data Recovery company to bring the information to you and do a hard repair for your precious Hard Disk.
i have that equipment and can do for you without any cost dear,
Hard Repair Company in IRAN
Счет 0
2 Комментариев:
Right! We are going to send our HDD s with our data to IRAN!
из Поделиться
Yes dear,
We will repair your Hard disk without any cost
из Поделиться
Try WD SmatWare Installer. if you can get to where it asks for Password type in 5 wrong answers it will then ask if you want to reformat say yes and you will lose all data on the drive but have the drive initialized and back working.
Счет 0
Добавьте свой ответ
Jimlberto буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 12
За последние 30 дней: 45
За все время: 30,769
