Компактная версия смартфона HTC One, выпущенная в августе 2013 года.
Powering on with a broken power button
Hello guys, I've been having kind of a big problem with my HTC. I dropped it a few times and the casing tore away from the top part and the bottom part of my phone, including the power button. normally I'd just get a new casing so I could use it, but the mechanism itself tore off too, meaning that getting a new button or casing won't really fix it.
I was wondering if there is a way to boot up my phone through my pc. I've been searching around and it seems to be fairly simple for most Android phones, however, since HTC One's block your access to the battery, I cannot use any of the tips others give me.
I do not have warranty anymore, so I'm not afraid of doing the bigger things. It is also rooted.
Right now, the phone is still on and I wake it up by using lock widgets and using the volume button. I am however still scared about not being able to charge it on time to keep it alive.
Thanks in advance!
Это хороший вопрос?
Счет 2
1 Комментарий
i am in your place but it had turned off
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
it's pretty easy if i remember right that power button does not require soldering so just order a new part and pop it in.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
as in disconnect the old broken one and connect that one.
из
how to reboot my htc one mini not working my power botton
из
Добавьте свой ответ
Alperen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 3,760
