Microsoft Wedge Touch Mouse — это компьютерная мышь для обеих рук, выпущенная компанией Microsoft.
Stuck at step one
I had a corroded battery and need to clean the contacts. This post has detailed steps but I can't get past step one.
The cover just will not come off. I can easily pry up the edges but it feels like there's something in the middle of the top plate that's attached and I don't want to break the mouse.
Step one mentions about moving the pick tool along the edge towards the battery cover and mentions a pin I believe. This just doesn't seem to work and I don't know what to do next.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Steve,
That would be a cable which is connected there. It has enough length that you should be able to separate the two covers if you do it firmly/gently/controlled. Just realised your questions is from 2014. Hope you figured it out.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Steve буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 16
За все время: 696
