Ноутбук Gateway P5WS0 в некоторых странах также продается под брендом Packard Bell. Модель P5WS0 входит в серию Gateway NV, ее можно идентифицировать по номеру модели NV57H58u.
How do I replace the keyboard?
How do I replace the keyboard on my laptop? I know that there is a tear on the left shift key pad that I found after removing the key to clean a sticky substance that I thought was the issue.
Это хороший вопрос?
Счет 1
1 Комментарий:
how would ou clean under the trackpad on this laptop? i have the same one and im wondering cause i need to clean mine
из Поделиться
Добавить комментарий
1 ответ
Hi Hurley,
As far as i know with the knowledge of the same model but from Packard Bell this laptop has sort of a "unibody" like a macbook.
U would have to remove the complete top cover by removing the screws sitting at the bottom and lift the top cover up as a whole to get to the keyboard.
Mind you that most of the times these top covers are extra mounted with clips so it might take a bit of effort to remove it. I would suggest to start from the front (the side of the touchpad) and move forward towards the back.
Hope this helps you in any way.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Hurley буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 4
За последние 30 дней: 24
За все время: 1,512
