Acer Iconia Tab B1-A71 — первый планшет из линейки Acer Iconia Tab B1, анонсированный в январе 2013 года.
Why the screen show White?
My Acer got white!! I was just playing some music, then i lay it down on the couch and went for something. When i returned the screen has got white and there was a crack in The middle, (not really, but it looked like an inside one ). But there was a black spot too. I turned it off and it turned black. Then i again turn on, but the screen appears as white ,black spot,and crack as it was. I tried to pull the notification bar. A sketch of bar appears but no icons or nothing. Help me please.
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Выбранное решение
Did you sit on your tablet? Or did it drop when you were away? Anyway, the fact is your tab lcd display was damaged.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
SO, should i have to change the lcd screen? And my sister was there too, according to her, the tablet was there laying, and it didnt even fall. She haven't lied. However, what to do with the tablet, and how to fix it??
из
You mentioned that your tablet had cracks, spots and blank screen, these are all hardware issues not software issues. A replacement display can fix it. If you'd like to DIY repair it, this is the part: http://www.etradesupply.com/acer-iconia-... and this is the guide Замена ЖК-дисплея Acer Iconia B1-A71
из
I have the same problem but my screen was already cracked
Счет 0
Добавьте свой ответ
Asad буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 2,711
