screen touch does not work after replacement?
I replaced the screen and digitizer and the screen comes on but touch doesn't work. I've checked all connections twice. What could it be?
Это хороший вопрос?
Это хороший вопрос?
jeyson, if you are sure that all your connections are properly seated, I would contact the vendor and replace the assembly once more. Sadly enough, it is not uncommon to receive a bad digitizer. Of course, you always want to double check your work, check to make sure that there are no bend or broken pins on the connector.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 22
За все время: 1,633
3 Комментариев
Jeyson......did you end up fixing this problem??
из Jason Gonzalez Поделиться
I have the same issue. My ZTE zmax pro z981 screen broke and I bought 2 new screens and after I put new screen it lights up but doesnt respond to any commands
из Nikola Tesla Поделиться
I have the same problem except mine's a ZTE n9521 screen not responding to touch
из br700973 Поделиться
