Двухъядерный процессор Intel Core i5 с тактовой частотой 1,8 ГГц или двухъядерный Core i7 с частотой 2,0 ГГц (Turbo Boost до 2,8 ГГц) и 3 МБ общей кэш-памяти L3
No Audio Input/Output Devices detected!
Hi All,
My Mac was functioning wonderful until, I upgraded to yosemite suddenly the audio input/output devices aren't detected! I have tried all the trouble shooting steps online NVRAM, PRAM to clean install of the software back to mountain lion and now running mavericks, but all in vain!
Took it to the authorized service centre they failed to diagnise my problem and detected fault on MLB (Main Logic Board) for which they are charging a bomb!
I would like to know if there is any work around to get the sound working! I read about external audio devices which doesn't require any drivers come in handy (Sabrent) should I settle for this? I am confused and frustrated with my MacBook Pro! Please HELP!
TIA
Это хороший вопрос?
Счет 3
2 Комментариев
Just so its clear here your built-in microphone and speakers are not working, correct? or are you having problems with the audio output phono jack?
из Поделиться
i am suffering with the same problem, the same model, and also dont find any solution for it.
Any solution out there?
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Have you looked at these? USB audio input/output adapters
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
xroadsinc буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 35
За все время: 3,439
