Серия 15,6-дюймовых ноутбуков Acer на базе Windows, предназначенных для обычных пользователей.
Quick question about adding RAM
Hello, my computer is a Acer Aspire 5742G, everything is as it was bought but recently due to overheating issues I dissassemblied it and cleaned the fan. Since then (or maybe a while after, I'm not quite sure), I started noticing it was getting very slow so I paid attention to my RAM and noticed only 2GB was being used (Computer Properties and Task Host say so) from the 4GB built in when purchased. I tried switching the RAMs' slots between themselves but only 2GB was being used still. I'm assuming I damaged one of the RAMs when I dissassemblied the computer so I'm going to replace it.
My questions are:
1-Is there any other reason why it's only using 2GB or am I right in assuming I damaged one of the modules?
2-Could I buy a 4GB module and have it pair with my working 2GB one? Then I'd have 4GB+2GB=6GB RAM. I haven't made up my mind whether I should or not buy a pair of 4GB modules so this could be a nice alternative.
Thank you in advance :)
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Hi,
Your computer support 8 gb ram (4+4)
So u can upgrade it to 8gb.
If you format ur pc before heating problem start even you clean the inside it s gonna be heat and shutdown. For fix this problem. You need to go acer web site and install the power management software than it s gonna be solve ur problem good luck
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
ruimendes10 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За все время: 450
