Шестое поколение беспроводной базовой станции Apple, выпущенное в июне 2013 года. Это устройство в башенном корпусе обеспечивает двухдиапазонный беспроводной доступ и является первым маршрутизатором Apple с поддержкой технологии 802.11ac.
Thermal pad replacement comments?
I took my AirPort Extreme apart to give it a clean because it was full of dust. I thought I would remove the heat sinks just for interests sake. When I removed the heat sink I noticed it had a thermal pad between the sink and the Broadcom router chip. I was a little disappointed this was not mentioned in any of the tear downs as I like to replace thermal pads when I pull things apart. I had to put it back together as was but I am looking to replace the thermal pad. Does anyone have any suggestions? Also any suggestions on pad thickness? I was thinking 3mm from memory. IT seemed like a fairly big gap from memory. Any comments greatly appreciated. Also from memory there was definitely only one thermal pad yes?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
These might work for you:
https://www.ebay.com/i/302812527840?chn=...
maybe these
https://www.amazon.com/Fujipoly-Extreme-...
or maybe one of these:
https://www.amazon.com/s/?ie=UTF8&keywor...
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
opinio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 34
За все время: 545
