Acer Iconia Tab B1-A71 — первый планшет из линейки Acer Iconia Tab B1, анонсированный в январе 2013 года.
How to replace charging port?
Im attempting a charging port replacement on the tablet, i've got the old charging port off without any issues however I can't get the mounting holes free from solder to fit the new charging port in.
Could anyone advise on what I could try, tried solder wick but doesn't help much as I can't get enough heat into the solder between the holes
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Position the new port with its feet in place, then heat the area (I used a heat gun carefully) while applying a little bit of pressure with a pair of tweezers.
The solder (or whatever it is) will soften with the heat and the port will sink in. Remember to remove the yellow tape from the topside first!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
EvansITLtd буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 16
За все время: 2,341
