Acer Iconia One 7 — это планшет, выпущенный в апреле 2014 года. Iconia One 7 представляет собой компактное устройство для мультимедийных развлечений. Благодаря дисплею, который больше, чем у фаблета, отличающемуся четкостью и красочностью, вы получаете быстрый отклик и длительное время автономной работы. Мы также включили платформу Kids Center с множеством интересного детского контента, который могут контролировать родители.
Acer Iconia One 7 Screen Digitizer Video Tutorial
Could you please make a Screen Digitizer replacement video Tutorial for Acer Iconia B1-730 ? is there any model that has similiar process of digitizer replacement and already published in your youtube channel ?
Это хороший вопрос?
Счет 3
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Hi There, I am looking for the exact same tutorial. Were you able to locate one?
Был ли этот ответ полезен?
Счет 1
I haven't found one. So I tried myself the replacement seeing similar tutorials with great success. Now, the tablet is working again with a new digitizer, however I still have a problem with the screen calibration. The digitizer is working good, however when I point my finger on it, the command is recognized in a different position, some centimeters above from my finger position. Anybody knows how to fix it ?
Счет 0
5 Комментариев:
Hi, Did you ever sort this - I am doing a repair and have the same issue! on two different digitizers!
из
Nop. Problem still remains.
из
I have decided that the digitizers sent are not 100% correct. They appear to fit perfectly but they do mask the edges of the lcd slightly. Tried a 3rd digitiser and still the same issue. I have a new tablet coming and will compare the digitiser measurments.
из
Looks like the only available digitizers are not 100% the same size, The side borders are too wide so obscure some of the lcd and the heights are a bit thick too. Has anyone replaced a digitizer with a ebay special and it work ok?
из
Hi Jon... the same happened here with my digitizer. The measures is not the same like the original one.
из
I want to repair my acer iconia tab 8 but i dont know where to found à new screen cam someone help m,e :( ?
Счет 0
I wanna ask on what button should I select to organize my apps?? Thank you
Счет 0
Добавьте свой ответ
ricartengenheiro буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 18
За все время: 2,486
