Battery vs. Charger Issues
My Garmin Nuvi 65LM won't turn on and I do not know whether it is the charger or the battery at fault. Is there any way of finding out without having to buy replacements for both?
Это хороший вопрос?
Это хороший вопрос?
You can use a standard MicroUSB phone charger to see if the Garmin charges.
Был ли этот ответ полезен?
Most chargers will have a light to show whether it is charging or not. If you are using a non-Garmin produced charger, an error message could appear stating that charger will not work.
Correct on all counts. However even though Genuine Garmin as came with device, red light appears ok but device does not boot from off setting when plugged-in and is thus is not charging. When device is plugged in from on setting it either turns off altogether or indicates battery not charging??? Friggin' Nuts..
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 17
За все время: 1,003
