Samsung Galaxy Note II — это смартфон, известный своим сочетанием большого экрана и программного обеспечения, оптимизированного для встроенного стилуса.
Cannot connect to wifi
my phone's wifi is not working
my wifi signal strength is very strong but it's not able to connect
the status shows obtaining IP address
and after a while it tells network disabled. Poor connection
I checked on the net they say it's because of the update of the phone original version 4.1.1 to 4.1.2 jelly bean, the update is causing the phone wifi connection go crazy
I checked for the solution, in many forums they showed to change the IP settings from DHCP to Static which I did and then after entering the wifi password there is no save option
I tried this way too..the link is below
https://www.youtube.com/watch?v=zyO66lqT...
the first way is dialing *#0011# but it's still not connecting
the second way was too confusing so I didn't try
I checked it online and I guess this problem does not only happen in note 2 but almost all the android phones
Это хороший вопрос?
Счет 5
1 Комментарий
I have the same problem suddenly in a day. I reset my phone once and I downloaded the wifi fixer, diff., versions, it just does not work.
из
Добавить комментарий
6 Ответов
Наиболее полезный ответ
my phone is not connecting to wifi and bluetooth
Был ли этот ответ полезен?
Счет 1
Hi Smriti
Have you thought about the wifi antenna being faulty and to try a replacement?
Счет 0
2nd Rssi is not available
Счет 0
disconnect then put your password back in. that what i did.
Счет 0
I can not connect wifi in my mobile
Счет 0
I would recommend replacing the WiFi antenna.
Счет 0
Добавьте свой ответ
Smriti Sharma буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 21
За все время: 25,865
