Выпущенный 24 июля 2014 года, Fire Phone — это первый смартфон компании Amazon, созданный для конкуренции с устройствами на базе iOS, Android и Windows Phone.
Fire Phone, Power Button Jammed
After a simple 2feet drop with a silicon case on my fire phone the power button is half jammed into the slot, creating a very sensitive button (causing it to display the lock screen at random times and turning on and off). Should I unscrew the star bits and see if I can pop the power button out? I know the warranty sticker will come off but I'm gonna need another phone anyways. Yeah or neah for adventure?
Это хороший вопрос?
Счет 2
1 Комментарий
i have broken my power button ribben how can i made this again without ribben
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
iam facing some problem while iam charging my fire phone. it does not charge b/c the battery is fully drained , when i plug the cable in a phone the switch on, restating continuing , i change charger & cable also but the problem same and not resolving
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
iam very great ful if some one have with a perfect solution,
plz share it
из
Sorry but you're toast well your battery is. This happened to me with my kindle fire and now it's sitting on my bookshelf till I get the nerve to open it up and place a new battery in it. If you contact Mayday all they can say is, "We don't have a fixing department, but I can get you a discounted fire phone ($165) since you're a loyal customer."They're abandoned the Fire Phone entirely. Though I was surprised about the recent update. The last update was in Oct. 2015.
из
no doubt. do it with confidence.
1) if you can fix it you win the game
2) If you cant fix it, you may learn a valuable lesson with practical experience
Cheers!
Счет 0
Good day ppl...I have a Amazon fire phone with two problems...1 is my power button....I have to press a bit hard on it to get it to light up the screen so I can unlock it. That's a pain.....An 2 in my phone when resting it keeps just saying Amazon an repeating it for about 3-4 mins then goes blank.....An help on what I can do....thanks in advance.....
Счет 0
Добавьте свой ответ
Rebecca Jarvis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 22
За все время: 3,319
