Where is the speed sensor?
My 1992 3/4 ton truck 4 wheel drive is throwing a code, 24 speed sensor failure, where do I find this sensor?
Это хороший вопрос?
Это хороший вопрос?
8 Ball it should be located on the transfer case output shaft.
Был ли этот ответ полезен?
It should be located on the driver side of the transmission near the rear where the transfer case meets but on some of them it is on the passenger side.
I do not have 4 wheel drive.
At the rear of your transmission on the transfer case just where your drive shaft slides in
За последние 24 часов: 0
За последние 7 дней: 10
За последние 30 дней: 66
За всё время: 39,781
1 Комментарий
I have a 1995 chevy 4by4 and the speedometer isn't work and it's not shifting into 3rd gear could it be a sensor
из Sheila Skorcz
