Can my cpu be fixed
a capacitor fell off the cpu. can it be resodered?
Это хороший вопрос?
Yes it can. You might want to check the value of the capacitor to be sure it is still good. I have had one drop off due to poor soldering. I was able to resolder it using a 25 watt soldering iron with a very small tip. I had to use regular 60/40 solder that melts at 360 degrees F. It worked. Just don't over heat the solder joint.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 4
За все время: 241
