Смартфон Samsung Galaxy Mega 2 на базе Android был анонсирован в сентябре 2014 года.
Camera Error and USB connection
Keep getting "camera failed" error message. Think I've tried everything..factory reset, clearing cache, undtalling flashlights,etc.. Also cant connect to pc via USB cable. Cannot select the "tethering and usb" function..stays blacked out. I need help.
Это хороший вопрос?
Счет 51
2 Комментариев
might be hardware damage, maybe water damage.
из Поделиться
I think it's time we all get a new phone
из Поделиться
Добавить комментарий
10 Ответов
Наиболее полезный ответ
Wiping the cache partition did not work till I then pulled the battery and reinstalled...
Был ли этот ответ полезен?
Счет 10
8 Комментариев:
Dear michaelbowerscore1st, thanks for that tip! It worked for me. Sorry, my Samsung. Eternally grateful.
из Поделиться
Thanks i just pulled battery and it works again.
из Поделиться
thanks mate , i made an account just to tell you that !
из Поделиться
This worked. Thank you kindly now!!!
из Поделиться
omg...thank you soo much it works for me!! Thank you! God Bless you..
из Поделиться
Показать ещё 3 комментариев
Here's one more trick you might try:
  • Turn your Samsung Galaxy S4 off and hold Volume Up, Home, and Power keys simultaneously until your smartphone starts to vibrate.
  • Let go of Power key and keep pressing the other two.
  • It will get you into Android System Recovery mode.
  • Press Volume Down to choose wipe cache partition and use Power key to select it.
Alternatively another trick I've used in the past:
  • Connect your device to your computer using a data cable.
  • Go to folder: Computer\SAMSUNG-SGH-I747\Phone\Applidium Image Cache
  • Delete everything in this folder.
  • Go to folder: Computer\SAMSUNG-SGH-I747\Phone\Android\data\com.sec.android.gallery3d\cache
  • Restart your phone.
Счет 5
4 Комментариев:
My computer cant find my phone.
из Поделиться
Thank you so much! the 1st method is work!
из Поделиться
Thank you thank you. It worked on my galaxy mega 2.
из Поделиться
have tried all this , nothing has worked. Screen freezes & goes half pink/purple.
из Поделиться
Im having the same problem as the OP, and tried the cache partition reset but still getting the camera failed error, and cant connect to my PC through USB. Any other ideas?
Счет 2
1 Комментарий:
If this doesn't work for you above, then I would suspect you could be dealing with a hardware component failure. The first and cheapest troubleshooting step is to replace the camera assembly. If that doesn't work, you could try the motherboard assembly.
из Поделиться
It definitely helped to delete flashlight app and take battery out and restart. Thank you. I now have my camera working
Счет 2
Samsung sm g750h Camera fail
Счет 1
If your mega2 Camera failed
First your mobile phone
Setting>
Date and time>at automatice date and time>mark making
All you do
Go to camera
Testing
Camera failed resolveing
Счет 0
เครื่องซัมซุง แกแลกซี เมกกา2 มีปัญหา camera failedต้องทำอย่างไรค่ะ
Счет 0
1 Комментарий:
ต้องการคำตอบจากคำถามค่ะ
из Поделиться
Had the same problem with a failed camera message and PC not recognizing USB connection.
Solution - Turn off the phone > Pull the battery > Hold power button for 3 seconds > Reinsert battery > Turn on phone.
Camera works from lock screen, cannot confirm beyond that.
Счет 0
Camera application is lost.What is doing?
Счет 0
Счет 0
Добавьте свой ответ
Sam G буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 34
За все время: 21,939
