HTC Desire 816 оснащен 5,5-дюймовым дисплеем с разрешением 1280x720, 13-мегапиксельной тыловой камерой и динамиками HTC BoomSound.
Right side heaphone jack not working
The desire 816's jack doesn't seem super solid in the first place. However, my 816 fell on a hard floor and now when I plug in any headphones to the jack, the right side earphone doesn't work. This seems like an internal issue in the phone. Wonder if you all have any solution! Thanks!
Это хороший вопрос?
Счет 1
2 Комментариев
i have this too
из
Connect the headphones to another device and check if they work properly. They probably won't because if the headphones Jack would have been not working then neither of them would have been working.
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
You may have to replace head phone connector
Был ли этот ответ полезен?
Счет 1
It looks like your head phone jack is failing. The head phone jack consists of spring loaded contacts and due to the impact it may have been bent out of place. It may be possible to bend the contact spring back to place however, if this does not work the only solution would be to replace the headphone jack completely.
Счет 0
First of all you need to go to the htc service center and ask them to change the earphone jack.
Счет 0
Добавьте свой ответ
Ryam Green буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 568
