Двухъядерный процессор Intel Core i5 с тактовой частотой 1,8 ГГц или двухъядерный Core i7 с частотой 2,0 ГГц (Turbo Boost до 2,8 ГГц) и 3 МБ общей кэш-памяти L3
Isolating MacBook no power issue
Hi Everyone,
I have a 13" Mid 2012 Macbook Air that has stopped turning on.
I have tried multiple known good chargers - no light on any of them.
SMC Reset, unplug battery + power button all did not help.
No activity at all upon powering on. There are NO battery status indicators on this model to tell if battery is charged at all..
I assume that it is either the logic board or the I/O..
Is there a way to isolate this between a faulty logicboard and a faulty I/O Board?
I understand the $90 I/O Board would be a better place to start then the $400 logic board - but was curious if there was anything I could do to test for sure which is the failed component. Is there a way to send power to logic board bypassing the I/O Board? It's likely the battery is completely discharged so I don't think shorting the pads did not seem to work, due to I'm guessing no power in the system.
Thanks in advance
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
There's really no way to tell until you drop in a new battery, get it started and run diagnostics.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Is there no way to power the mainboard directly?
из
I have a similar problem with my MacBook Air Mid 2013. Was working great the previous evening, then the next morning it would not power on. Plugged in with a new power cord - nothing. Replaced the I/O board, nothing.
Does this narrow it down to the logic board?
из
Добавьте свой ответ
mikejensen13 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 854
