Canon EOS 7D стала первой профессиональной камерой Canon высокого класса с кроп-сенсором APS-C.
Frames per second are slowing down... Repair?
I have a Canon 7D that I use primarily for sports photography, so the multiple frames per second feature has been used a LOT. I have noticed that it is skipping or slowing down. Where one press of the shutter used to result in 7 shots in a row, now there is a break and they are spaced differently. I don't think I have changed an internal setting to get this result (although I will check).
Is there a way to repair that particular feature with good result? I photograph horses, dogs, humans in sport, so often track and take multiple images.
MFA
Это хороший вопрос?
Счет -1
Добавить комментарий
2 Ответов
hello MFA,
The fault can be occur due to bad memory module. Change the memory (Flash) card and shoot. it should work.
Был ли этот ответ полезен?
Счет 0
Note that the 7D will slow down considerably in bad lighting situations! This is independent of your shutter speed and aperture settings! To check, use with lens cap on: fps goes down to approx. 3/s. Point at a lamp or use in daylight: fps goes back to 7/s.
Счет 0
Добавьте свой ответ
MFA буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 13
За все время: 333
