Двухъядерный процессор 1,6 или 1,8 ГГц, 2 ГБ или 4 ГБ SDRAM, SSD 64 ГБ или 128 ГБ
Fan always going how to fix
My fans on my macbook air won't stop turning. They have not switched off unless I shut down the laptop or closed it. Its not over heating, the CPU is 0% and I have tried everything and nothing is working!!
Это хороший вопрос?
Счет 2
2 Комментариев:
Why/when/how did this issue arise?
из
Why you want stop turning fans? They must cooling down laptop its okay, or its to loud for you?
из
Добавить комментарий
1 ответ
The temperature sensor may be faulty ? Try installing a Fan Management App.
http://www.macupdate.com/app/mac/23049/s...
This will give you control of your fan speed but more importantly the temperature of your CPU.
Maybe it just needs a good cleaning to ensure it's cooling down properly.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Unfortunately Fan temperature is OK. Apple Genius ran some tests and also didn't find any problem. I tried to clean it inside and still no result.
из
Добавьте свой ответ
moxno буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 1,433
