AirPort Time Capsule — это беспроводной маршрутизатор и сетевое хранилище (NAS), производимое компанией Apple. Модель A1409 представляет собой четвертое поколение Time Capsule, выпущенное в июне 2011 года.
2 TB time capsule
The time capsule requires unplugging and re plugging in power cable to get it working again. Is this a power supply problem or likly a board problem?
Это хороший вопрос?
Счет 6
Добавить комментарий
5 Ответов
Выбранное решение
This might be of some help :
LaPastenague - Gen4 A1409 issues
Был ли этот ответ полезен?
Счет 3
9 Комментариев:
Worked!!! Thanks!!!
из Поделиться
Thanks for that input. I'll start there.
из Поделиться
Apple pie baking solution worked for me also very well
из Поделиться
i baked the Apple i get it bak but the WLAN dident work after a HARD RESET no more connection with WLAN only with LAN
из Поделиться
Same ‘Dead’ TC issue here. When I read the part of putting the part in the oven I really thought it had to be a hoax.. It bloody Worked!! I can't believe it... My level of knowledge is not soo good that I understand what actually happened there but... It's ALIVE!!! Thanks :D
из Поделиться
Показать ещё 4 комментариев
Probably just tripped by a surge, check your power outlets.
Счет 0
Like daveedwards, all I get of my TC is the solid amber light when I power it on. Multiple resets don´t work anymore, no flashing lights but the HDD is spinning. I decided to open and remove the drive. Now I´m waiting the arrival of the caddy I bought to connect the HDD and hope for the best. I´ll Keep you posted
Счет 0
has anyone got the answer to solid amber light not responding to resets?
Счет 0
I cant say for sure, but judging by apple products, they have a long history of bad power supply so i would go with that.
Счет -1
4 Комментариев:
Care to give us some links to this blanket statement?
из Поделиться
My TC has became steadily less and less reliable to the point where all I now get is the solid amber light when I power on. Multiple resets do nothing - no flashing lights or any sign of activity. The HDD appears OK, I can hear it chirping when I power up. Is there any solution or should I just remove the drive and put in a chassis?
из Поделиться
из Поделиться
Seems to have fixed my TC. Let’s see how long this will last. Great guide!
из Поделиться
Добавьте свой ответ
Frank Bibbee буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 26
За все время: 16,299
