iPhone 5S little water damage. How to clean it?!
Hello, i've got my hands on an iPhone 5s gold wich has never been openend before. But it has (sadly) water damage. I took it appart today and i cleaned te connectors of with 70% denaturized alcohol. Still no power.
The water damage is on the bottem section where the battery connector and dock connector is. And there was a littlebit of rust on the sim slot. I removed the logicboard but there are no stains or rust/corrosion on the big EMI plateon the underside. The battery connector got corroded and so for the actual battery connector so i think i have to replace that one. But the dock flex was fine but it still dind't powered on without the battery connected while plugged in the charger. Is that normal? Screen is absolulty fine i tested this one on an known working iPhone 5S logic board. And it was only at the bottem where the battery nonnector is and where the loudspeaker ect is. How can i completely clean it and is a battery replacement needed? It doesn't turn on without.
Touch ID connector got a veeeeerrryyy little bit of corrosion to but thats already gone! :D but the water damage was minimal but it rusted due to its time been like that.
Every answer is more then welcome!
Btw its an gold iPhone 5S]
Это хороший вопрос?
3 Комментариев
[image|591460]
[image|591457]
[image|591456]
[image|591459]
[image|591455]
[image|591453]
[image|591458]
[image|591454]
I posted some macro shots, can you guys see some burning or missing components? I can't see the at al! But you guys are better in this. Let me know! And btw the rear camera is free of dust and moisture so that tels that it wasn't hapeavy and it was only at be bottem section.
If you are wondered why the water sensor at the top left is triggered, thats because a dumped this logic board in 70% denaturized alcohol and it has water, before this it was clearly white. Hope you guys help me furter!
I'll get some isopropanol later this day with destilled water :D
из LorenzoVHH
[image|591807]
This is the capacitor!!!
из LorenzoVHH
Lorenzo VHH you can only add images to the original question or to answers, not to comments. Use this guide Adding images to an existing question to add images to your question
из oldturkey03
